I think you're doing the right thing.... standard height, tall snow tyres on 5.5x14 Comp THs, a set of cibies and you're laughing! ;D I know I am doing the right thing ;D This is just further development of what works out there, and has already been proven over the last 4 years ;D If you are offering a set of TH`s then I would be very interested too ;D
If I had a set of THs I most definately would NOT be offering them to anyone
Oct 13, 2007 18:22:36 GMT
Well been over to nightmares Manor today ;D Saw the van again which looks more awsome the more you see it, oh and a Mate saw you Launch it this morning away from the lights and was very impressed ;D Caught up with RevD Deluxe, EvilGed and his missus as well which was nice Sufice to say the Nightmares Magic and short Timelines extends to Golfs as well as `tinas and Kadetts ;D Its all in Primer, the 1st colour has gone on and the top coat should be on Tomorrow apparently !!! ;D Its looking very cool as well .... Janey was extremely happy which is the most important thing ;D Thanks again Fella and look forward to the pics when its all coloured ;D Cheers Dom
Last Edit: Oct 15, 2007 9:31:17 GMT by CR500Dom
Oct 13, 2007 19:25:56 GMT
Oct 13, 2007 19:33:07 GMT
Only the roof competed and its already got nightmares written all over it BTW what happens with plat and polish? wet and dry paper then a polishing spinning machine? Is there anyway a DIYer can do it without the polishing tool? PS love the new Siggy, its perfect!
Oct 13, 2007 20:09:31 GMT
Only the roof competed and its already got nightmares written all over it BTW what happens with plat and polish? wet and dry paper then a polishing spinning machine? Is there anyway a DIYer can do it without the polishing tool? PS love the new Siggy, its perfect! cheer's your pretty much right with the flat and polishing flat down with 1500 grip wet and dry with plenty of soapy water the put some rubbing compound on and polish it up with the machine , you can do it by hand but it a hell of a lot of work ;D cheer's for coments about the sig a mate on another forum did it for me
Last Edit: Oct 13, 2007 20:10:48 GMT by Deleted
Oct 13, 2007 20:16:26 GMT
I'm browsing using my phone so colours don't always show up correctly.....But is that high gloss black with large blue flakes?
*n
Oct 13, 2007 20:37:21 GMT
close its panther black with rainbow flake ;D
Oct 13, 2007 20:51:24 GMT
absolutely gorgeous is what it is!!!!! Lovin the flake looks awesome!
Dean
Sterling effort..... AGAIN !!
Who knows..... would one be able to sussesfully drop a 2.0l Turbo 20V motor into one of these Synchros ?? Without risk to the Drive system, and also would it be close to plug and play ??
Or should one stick to FWD Golfs ?
Oct 14, 2007 10:17:19 GMT
Sterling effort..... AGAIN !!Who knows..... would one be able to sussesfully drop a 2.0l Turbo 20V motor into one of these Synchros ?? Without risk to the Drive system, and also would it be close to plug and play ?? Or should one stick to FWD Golfs ? Nope fraid not , the weak point on the syncro system is the amount of torque it can handle, the Rallye system was heavier duty but is still limited. The 4 motion Haldex system however will take lots of Punishment and its what the really big power 4wd Golfs run, but it is a bit of a nightmare to hook up...... mechanically its fine, its the electrics and control system thats not easy at all..... This is going to run a bit more power but not a lot, the 8v is a lovely grunty engine and suits the car and the conditions its used in perfectly a bit more go would be nice though for the uphill overtakes ;D sometimes you just don't quite have enough especially if its a TDI you are up against and they don't want you past (Despite them not knowing the road and being painfully slow on all but the straighter bits ) A syncro on snow tyres and decent suspension is the Ideal tool out there, just a little more power would be nice... I have a Fully ported Big valve Head and 267 cam to go on but it needs more work than I was originally lead to believe so I doubt it will be ready for this winter the plan is to get that built up to run on bike carbs, providing I can get it all to fit and run without the Carb Icing which the golfs are reknowned for and bikes suffer from too - combining the 2 on one car used in -20deg ambient temps could be interesting
Oct 14, 2007 18:23:07 GMT
Oct 14, 2007 19:27:26 GMT
Fresh! Thanks for the answer BTW, I'm currently painting the rear quarter of my van, which is is good for skill building, I'm now gonna give the whole fugger a freshen up just cos i can and it'll look loads better , So either a bulk load of small cans or i'll hunt down some propper paint from somewhere and a spraygun, and pop my cherry! ;D ;D
Oct 14, 2007 20:31:19 GMT
Looks Great Fella ;D Top Job Janey says thank you too ;D
Oct 16, 2007 22:39:28 GMT
Delightful! Hopefully one day I can convince you to paint one of my cars Your work is top notch.
qwerty
Club RR Member Number: 52
Awesome work!! Looks fantastic! I have a Fully ported Big valve Head and 267 cam to go on but it needs more work than I was originally lead to believe so I doubt it will be ready for this winter the plan is to get that built up to run on bike carbs, providing I can get it all to fit and run without the Carb Icing which the golfs are reknowned for and bikes suffer from too - combining the 2 on one car used in -20deg ambient temps could be interesting Would it not be better to fit the Fuel injection System of a GTI? Should improve performance (although prolly not as much as bike carbs) and cold start, maybe even MPG. Prolly a safer bet than bike carbs in the snow.
Last Edit: Oct 17, 2007 7:23:58 GMT by qwerty
Oct 17, 2007 13:15:06 GMT
Would it not be better to fit the Fuel injection System of a GTI? Should improve performance (although prolly not as much as bike carbs) and cold start, maybe even MPG. Prolly a safer bet than bike carbs in the snow. Well for me its probably as much work and more of a P I T A to fit Inj to the Syncro, than it is to make a manifold to take bike carbs (which could also be used with Bike TB`s as well if going injection) The syncro has a different tank to a normal 2wd Golf due to the addition of a Diff, Viscous coupling and driveshafts so I would need to find a Rallye tank and pump arrangement as well. Then there is the wiring loom swap etc etc Cutting up an injection manifold, making a new plate for the R6 inlet rubbers and joining the 2 together seems a lot easier to me and can be done and built up off the car. The Injection swap means car off the road, as well as new head, tank, loom, sensors, pumps etc etc to find fit and get working... If I was going to go to that extreme, I would fit a TDi motor instead ;D
Oct 17, 2007 21:01:24 GMT
Last Edit: Oct 17, 2007 21:07:01 GMT by Deleted
Oct 17, 2007 21:28:30 GMT
That looks ace ;D Janey is going to love it ;D Cant wait to see it in the metal now ;D Thanks again fella, give us a shout tomorrow and we`ll get your new engine unloaded ;D Cheers Dom
