topi
It's a race car officer, I swear!
Ah-ha, interesting So all that was needed are some engine mounts? Did the gear selector line up ok, or do you need to cut the tunnel up a bit?
i will need to cut about 6" back from the origonal selctor hole and around the selctor hole flip it round so the origonal hole is sitting 6" further back and job done its sitting on all cortina mounts gearbox mount is an auto one bolted through the floor with plates welded into the floor to reinfoce it once the interior is back in the center consol will just sit back slightly so should look pretty stock
topi
Awesome I've got a 205block engine with a 5spd T9 from a P100, might build it up nicely and do the same.
Mr K
man, that bulkhead raely was made for it!!
looks good, I assume that this will make it vastly faster than the stock 1256?
i love the way chevette turrets look like they just stabbed it with a sharp bit of metal from underneath to form the shape!
Last Edit: Dec 9, 2006 22:45:11 GMT by Mr K
mounts need a fair bit of work and we did modify the mountings on the crossmember aswell as they tend to be a little week in that area other than that it is a pretty simple swap
man, that bulkhead raely was made for it!! looks good, I assume that this will make it vastly faster than the stock 1256? I love the way chevette turrets look like they just stabbed it with a sharp bit of metal from underneath to form the shape! yeah we were realy happy with the way it looks now and yes it will be one hell of a lot quicker the pinto has had some mild work in the past and will be getting a fair bit more aswell ;D ;D i know what you mean about the turrets ;D ;D
darren lewis
heaven wont have me and hell knows i'll take over
looks good mark
Dec 10, 2006 11:31:55 GMT
gonna be a good un what axle are you putting in ?
Dec 10, 2006 12:01:17 GMT
why am i always amazed when cars have large engine bas....oh yeah i drive a mini. forgot.
Dec 10, 2006 12:19:13 GMT
Shuvs were made for transplants - huge bay, set-back bulkhead, massive trans tunnel...
*n
topi
Dec 10, 2006 13:00:57 GMT
Oh yeah, what prop are you using? Chevette diff etc still?
Dec 10, 2006 13:10:07 GMT
Great stuff! Anymore pics of the rest of the car?
You've been telling me you were a genius since you were seventeen ... in all the time I've known you I still don't know what you mean !
Dec 10, 2006 14:48:38 GMT
yeah,for all they're a 'small car' they do have a deceptively large engine bay..
greaz
Dec 11, 2006 19:52:43 GMT
bloke at a local breakers yards planning tthe same conversion, into his hsr replica
Mr K
bloke at a local breakers yards planning tthe same conversion, into his hsr replica wouldnt another slant 4 be more in keeping with an HSR? like a dolly sprint engine or somthing?
Dec 12, 2006 10:08:59 GMT
Or a slant 4 vauxhall?
Mr K
Dec 12, 2006 19:49:30 GMT
that would be too obvious! i was trying to be different!
greaz
Dec 12, 2006 20:00:17 GMT
i think he just had one out of brischa stock car lying around, its not a full on rep just a kit
Dec 12, 2006 20:20:10 GMT
gonna be a good un what axle are you putting in ? he gonna keep the chevette axle for now but he has got a manta axle to go on at a later date ( probably about 5 mins after the first drive of it when he pops the shov axle ;D ;D )
