street
6.2 ft/lbs of talk
Mar 29, 2008 11:39:17 GMT
I've seen people quoting multiple people in their replys..... how do you do that? The answer will probably be painfully simple but damned if I can figure it out!
Odin
Mar 29, 2008 17:13:20 GMT
I just go to quote one person, and then have my actual reply open on another tab/window. Copy and paste it over, eh voila.
I don't think this forum software has a built-in multi quote option like some do.
rysz
Mar 29, 2008 18:45:29 GMT
Like that?
Just copy and paste all of the information in the thread and surround it by square brackets quote close square brackets and / square brackets quote close square brackets.
Just look at this post to see the method.
Rysz.
Seth
Mar 29, 2008 19:50:40 GMT
I just go to quote one person, and then have my actual reply open on another tab/window. Copy and paste it over, eh voila. Sounds like what I do. Two R-R tabs open! Use one to quote a for a reply then paste it into a reply in the second tab made up of the numerous quotes.
no, like this I've seen people quoting multiple people in their replys..... how do you do that? The answer will probably be painfully simple but damned if I can figure it out! I just go to quote one person, and then have my actual reply open on another tab/window. Copy and paste it over, eh voila. I don't think this forum software has a built-in multi quote option like some do. Although laboured, i think opening two windows is the only way
street
6.2 ft/lbs of talk
Mar 30, 2008 19:08:54 GMT
Ahhhhhh, never thaught to open two windows! I have used your method Rysz in the past and probably will when I cant be bothered with two windows I just go to quote one person, and then have my actual reply open on another tab/window. Copy and paste it over, eh voila. Sounds like what I do. Two R-R tabs open! Use one to quote a for a reply then paste it into a reply in the second tab made up of the numerous quotes. Like that? Just copy and paste all of the information in the thread and surround it by square brackets quote close square brackets and / square brackets quote close square brackets. Just look at this post to see the method. Rysz. no, like this I just go to quote one person, and then have my actual reply open on another tab/window. Copy and paste it over, eh voila. I don't think this forum software has a built-in multi quote option like some do. Although laboured, I think opening two windows is the only way Cheers all!
bstardchild
Club RR Member Number: 71
Multi quoting?bstardchild
@bstardchild
Club Retro Rides Member 71
Although laboured, I think opening two windows is the only way I quote the first post - copy and paste into a txt doc - brouser back and then pick up the next post and quote that copy and paste etc etc Then edit it all in the txt doc and reply as a new reply using all the info in the txt document I hope that make sense
