I've already looked at the other threads to try to work out how to tidy up my links.
Even the three easy steps one i can't get my head round, my brain is obviously not designed for computer jargon.
Anyway, my main question is how do i link a photo to my thread when posting up an e bay item? (Or am i just thick?)
Cheers
OAP drifta Volvo 340,Williams power 1960 Beetle twin 40's 1776cc
E bay stuffarthurbrown
@GUEST
On eGay, right click on the photograph. If you are using Firefox (which is the bestest) you will get an option to 'copy image location'. Select this and return to the retro-rides environment. Open an image tag [img] and paste (right click > paste) the image url, then close the tags [/I'mg]... Should look like this: [I'mg]http://i8.ebayimg.com/01/i/000/86/57/0623_1.JPG[/img] And when you click 'post', will give you If you are using Internet Explorer (which is crud), then when you right-click for the image properties you have to highlight the url of the picture, then right click > copy... then just do as outlined above. HAPPY DAYZ.
Jan 23, 2007 20:07:01 GMT
Yep sadly using Explorer, not my fault my bro's PC, suppose i should invest in one myself.
Thanks for that though.
bstardchild
Club RR Member Number: 71
E bay stuffbstardchild
@bstardchild
Club Retro Rides Member 71
Jan 23, 2007 23:01:43 GMT
Yep sadly using Explorer, not my fault my bro's PC, suppose I should invest in one myself. Thanks for that though. And if you still struggle ClickyMust see if I can get that one made a sticky!!!
