included is:
overhauled cylinderblock, new pistons rings etc, with around 1500kms on it (car was totalled after complete restoration)
cam is fast road, according to former owner, but not sure about that.
comes with:
overhauled cylinder head, new valves
new waterpump
new bolt kit (excl head bolts)
new ignition coil (high perf)
used parts (greasy stuff)
extra sump
alternator
starter motor
oil pump (new ones available on ebay)
pulleys
flywheel
missing (needed to make it complete):
rocker shaft
head gasket set
ignition distributor
I was thinking of around 300-350 pounds for the lot, if we come to a deal it can be picked up in Eindhoven (the netherlands) or I can take it to RR08.
the curse word you see is some tape:
comes with:
new waterpump
extra sump
alternator
starter motor
pulleys
flywheel
rocker shaft
head gasket set
