Jan 29, 2008 19:17:54 GMT
3dr, Red, 1.4, 115k, pas, e/w, cd, tax till end of feb tested till july had a 47k engine n box, trailing arm and interior fitted at 100k and I fitted a new clutch last week. it dose have slightly lower springs and slightly stiffer shocks fitted as shown in some of the photos and a KnN fitted The only bad points is the release bearing is noisy! and it is not mint condition! It has been my daily driver for 5 years it handles well and gets 40mpg cheap to insure I need to remove a private plate from the car and it will be reddy to go! the car is in Gloucester
1970 MG midget 1974 MG midget 1992 Audi 80 2.0 16v 1998 Seat ibiza
Jan 29, 2008 19:27:35 GMT
Pictures/price/location/mileage?
Corsa Apology Champion 2014.
Jan 29, 2008 19:46:56 GMT
Pictures/price/location/mileage? ABOVE^^^^^^^
Jan 29, 2008 21:38:16 GMT
Very interested in this mate. sounds a bit too good to be true? is there much rot about sills arches ect?
there is absolutely no rust as it is hot dip galvanized and waxoled at the factory, like all modern V.A.G. cars. it came off the same production line as the vw polo mk4, with more or less the same running gear!
the reason for the low price is that it is far from a clean example and the release baring is noisy
10mpg
Club RR Member Number: 204
98 seat ibiza £400 ono 10mpg
@10mpg
Club Retro Rides Member 204
I think i may have to have this!
did you replace the release bearing when you did the clutch?
I'll let you know for definate by 6 tonight (check with the missus) But I'll proably 'ave it!
Jan 30, 2008 10:53:42 GMT
It looks exactly the same as a Polo doesn't it!!
Jan 30, 2008 11:07:42 GMT
i changed the bearing was replaced yet after a hudred miles it was noisey! i am not sure why it started making noise possably a poor bearing or fitment but it runs fine! give me a ring if you have any questions 07799037750
Rob M
Club RR Member Number: 41
98 seat ibiza £400 ono Rob M
@zeb
Club Retro Rides Member 41
Jan 30, 2008 14:34:20 GMT
I had one of these ( a Turbo Diesel) when I lived in Mallorca. They are blindingly good cars. Definately better than a Polo!
Jan 30, 2008 17:59:12 GMT
Probably a good point to make regarding the clutch is that it is not a difficult job whatsoever to remove the gearbox and fix the clutch (which I think has something misaligned) John and I have removed and refitted a gearbox on this car in 3 hours in the driveway before now.
10mpg
@10mpg
Jan 30, 2008 18:12:54 GMT
I am very interested.
When would be a good time to come and see the car?
pm sent
