Hi, having a garage clear out, if anyone wants any of it let me know by pm or email, pics of some of them are here:
pressed steel steering boss that I think fits a triumph spitfire - free.
Citroen CX lights – one front RH and rear LH £5 the pair
cortina mk1 1500 super gearbox, you can use this in hot Anglias apparently. Was supposedly re-conned, and looks it inside but the outside has surface rust from sitting in damp garages for ten years and probably wants another bearing on the input shaft. £10
2x 100E gearbox, condition unknown £10 each
black vinyl bench seat from the rear of a Renner 12 - ideal for a hot rod or living room furniture. ex cond, doesn't look that good in the pics but that's just dust. £10
A pair of brand new, heavy duty Volvo 240 rear springs, cost £60, bought them to chop and stiffen the back of the estate but never got round to it before I sold it to Tigran, £30 no offers. I think I've also got front and rear inserts as well, better have a look
Brand new Sachs gas strut inserts - got these with a Datsun, I think, but they say Peugeot on them, the number's 200427, if you know what they are you can have them for nowt as a prize
Moroso wedge spacer for squarebore carb with gasket £5
I've got a honed standard bore Mopar 360 block as well, if anyone wants it. It's got good pistons with new rings, but I'm hanging on to the crank (although I've got another crank that has surface rust so needs a grind which you can have). The reason it's not in my car is that the engine mount is broken off the casting but could make a basis for a stroker or spare block for a drag car or anyone else who's going to use a motor plate. It's free. I've got lots of other small block Mopar engine parts so ask if you looking for anything, I might have it somewhere.
The bits are in South London or High Wycombe, I might be able to bring some small stuff to the Ace but otherwise you'll have to come and get them at weekends.
