Dec 15, 2007 18:23:46 GMT
As per title really - got about 6k to spend, might push a little more for something interesting or spot on. Doesn't have to be a well-recognised car either...or, I guess, a muscle car.......American classic probably a better description!
Must have T&T really, as I want something I can start using straight away and enjoy.
Just wanted to put this out there in case anyone knows of anything interesting!
Not marque or car specific either - if it's got 8 cylinders, runs true and strong then give me a shout!
Thanks!
Last Edit: Dec 15, 2007 18:30:31 GMT by Lewis
Hirst
This avatar is inaccurate, I've never shaved that closely
Dec 15, 2007 18:35:38 GMT
I reckon you should get a Buick GSX. I don't know where there are any for sale, but COME ON! It's lovely.
Dec 15, 2007 18:41:18 GMT
That is nice!
10mpg
Club RR Member Number: 204
WTD : 60's/70's muscle car10mpg
@10mpg
Club Retro Rides Member 204
Dec 15, 2007 18:55:34 GMT
I'd look for a either a late 60's fastback 'stang or '68 camaro,maybe an early 70's bull nose...
Dec 15, 2007 18:58:32 GMT
Aye - got Firebirds on the list as well - but that more respected stuff has quite a hefty tag attatched to it in most instances (damned scene tax )! AMC Javelins too, those are quite sweet. I suppose I'd consider something 80's if it were proportionally cheaper, too...
Dec 15, 2007 22:54:26 GMT
Aye - got Firebirds on the list as well - but that more respected stuff has quite a hefty tag attatched to it in most instances (damned scene tax )! AMC Javelins too, those are quite sweet. I suppose I'd consider something 80's if it were proportionally cheaper, too... From the NSRA Forum....dunno if this is the sorta thing you're after. Early 1970 V8 Duster fitted with 340 auto. !970 year had emblem on grill and a flat trunk lid ( no ridge in centre of lid ) It looks like it was restored in the states as a daily driver with lots of new parts fitted for reliabilty, Shoxs, propshaft, Torsion bars, brake parts, radiator , alternator, starter, exhaust etc. It has a 489 case 8 3/4 axle with economy gears for good mpg. The 340 engine is fitted with cast HiPo exhausts, Edelbrock ally LD340 inlet with just fitted Holley 670 Street Avenger carb and K&N element. polished MP R/covers. leccy ign. MSD leads. New 700 amp battery. new recon P/S/pump. I have just changed the Morris 20/50 oil and filter i put in 500 miles ago for Kendall GT1 20/50 oil. The interior is nice and unbutchered with buckets and centre console. front and rear seat belts. original radio still in dash with modern Sony radio/CD under the air con vents. ( air con removed, but have parts ). Tinted glass. Rev counter.oil pressure gauge , and working fuel gauge. California car so body is very solid and straight and was resprayed pale yellow with new vynil roof last year. Ralley wheels with correct 70 centres and new chrome lug nuts. Free tax Nov 08 .... MOT June 08 .... Insurance valuation £9000 With the Holley 670 Street Avenger carb at the Hot Rod Drags it ran 14.9 @ 96mph with the motorway gearing, so will run much quicker in needed. Finish detailing and use as a great classic Mopar or make it faster with a change of gears in the 8 3/4 axle. I lost reverse gear at the HRD's but drove the car home ok. I have just had another autobox rebuilt and have also had a shift kit fitted. This can be fitted with the standard or a higher stall converter by the new owner. I need to get back in the garage to get my Hot Rod back together so the Duster needs to be sold. It's valued at £9000 for insurance. It still has forward drive, but as the supplied rebuilt auto needs to be fitted i am selling it for only £7000 so grab a bargain. REDUCED to £6000 ono for quick sale Cheers Andy Here's the link, I dunno if non-members can access it though. if not, PM me if you're interested and I'll pass your details on. www.nsra.org.uk/newforum/showthread.php?t=1478
Dec 15, 2007 22:57:31 GMT
ZOMG! I was just looking at that on the Mopar forum but it was up for a considerable amount more! <goes back to read> Thanks for bringing it up - I did look thro' the NSRA today but not obviously deep enough! No reverse though which is a slight PITA - but I'll have a gander anyway
Last Edit: Dec 15, 2007 23:01:11 GMT by Lewis
Hirst
As a bonus, those look like the same trim rings as used on my Galant! So if you lose one, you can have one of mine.
iainb
No reverse though which is a slight PITA - but I'll have a gander anyway I'm reading that as it has a spare box & a choice of normal or high stall converter?? "I have just had another autobox rebuilt and have also had a shift kit fitted. This can be fitted with the standard or a higher stall converter by the new owner" Duncan is a guru on Mopar boxes as well ;D
Last Edit: Dec 16, 2007 0:19:18 GMT by Lewis
Hirst
Dec 16, 2007 14:52:35 GMT
COR! That's lovely, so much cooler than the more obvious choices.
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Dec 16, 2007 16:37:24 GMT
that GS350 is actually my ideal everday musclecar, one day, one day.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
87iroc
Dec 16, 2007 18:05:53 GMT
I'd look for a either a late 60's fastback 'stang or '68 camaro,maybe an early 70's bull nose... all nice cars mate but ,in good condition, also all around £12 - 15 k + (good firebirds can be found cheaper though)
Dec 16, 2007 20:17:25 GMT
or u could buy my "european muscle car", the Manta A series in my sig which is up for sale
10mpg
@10mpg
Dec 16, 2007 23:46:26 GMT
Thats a very sweet looking buick there matey...
you could buy quite a sweet 71 Mustang Mach 1 for that..
Last Edit: Dec 16, 2007 23:47:53 GMT by 10mpg
