I bought this lot to aid converting my nissan a while back, but I happened across a set of tein S13 coilies with camber adj. mounts so I'm using those instead now.
they fit 2" struts. theres 4 springs, all 6" long, they appear to be 2 pairs of slightly different weights, but the weights aren't written on them.
the long collars offer 3" adjustment and the short ones 1". they have rubber washers to fit betwixt the springs and cups and stuff. they're isn't any conventional top mounts there but the short collars do have a top mount inside them, it appears they're supposed to fit 'upside down'- I was told this it is designed for a focus, but I wouldn't know about that, mostly cos I know knob all about focusususususes
either that or get a pair of top mounts from rally design for £15 and wang them on.
I'm sure you could do at least one end, if not both, of most cars with everything thats in this kit.
£50 the lot, gotta be worth that for the springs alone.....
