Complete with Steel Torque Tube
If you are building a Chevette or Kadett with more than 100hp you will need a stronger axle, this will fit and still allow you to fit decent width wheels under the standard arches as only 1" wider track that the Chevette axle (Manta B is +2")
For sale shortly as no longer needed due to Piazza LSD axle going in with a full 4-link kit
Already Cut down front mounting to fit straight on to Kadet or Chevette and Panhard rod location swapped to suit as well
May need brakes looking at.... I think it definately has back plates not sure about the rest ? As I was going to disc brake it
Cleaned, wirebrushed and Had 1 coat of Silver Hammerite
Sensible Offers on here first otherwise I`ll Ebay it :wink:
Cheers
Dom
Cheers
Dom
