Weber 40DCOE for sale, looks in excellent condion, but I've never personally used it. Bought it for a project etc.. Comes with a K&N filter. Pic will follow when I've taken some. How does £80 sound? or £120 & I'll throw in an inlet manifold to fit it to a Toyota K engine
any pics?
how much does it weigh (without the manifold) - ?
Pic added, not sure on the weight, I'd giess 1-1.5kg?
thanks, is there a serial no. on the tag?
I'm thinking about a ford-use for this carb - i will look around to see if a suitable manifold is available
I'm sure there is a Serial number, I'lll have a look & let you know. Pretty sure Ford manifolds are fairly common, Lynx if i remember rightly? Also has a pair of 40mm trumpets & spare chokes, but I don't know what size. There is a very small amount of damage on the casting on the far left as you look at the picture, just below the phillips screw. It won't effect the carb at all, but thought I'd better tell you.
