Mar 24, 2008 20:18:56 GMT
After some help from bodieanddoyle regarding fueling the planned pinto turbo on boost. I am a little stuck with how to get oil to the turbo. I initally thought about using a sandwich plate designed for an oil cooler, but this would mean having a long feed pipe (which I have been told is okay) and a long return pipe (which I have been told is bad). I spoke to a Lecture at College who suggested using a oil pressure T-piece and instead of using it for an oil pressure gauge, use it as an oil feed to the turbo. Is this a good idea, or would I loose oil pressure to the head? Found this on ebay, seems like it would be up to the job....... cgi.ebay.co.uk/SIERRA-ESCORT-COSWORTH-TURBO-OIL-PRESSURE-GAUGE-ADAPTOR_W0QQitemZ180226278808.....for the drain/return, there is a conveniant threaded hole at the bottom on the block on the exhaust side, which will sit nice and close to the turbo. This appears to lead straight to the sump. And from the pics I have seen of the TT conversion was used by them as a return to the sump.
Mar 24, 2008 20:29:52 GMT
Seeing as most of the question we ask we already know the answers to and are mearly seeking confirmation of the fact all i will say to this is....
Yes ;D
Mar 24, 2008 20:32:27 GMT
Cool! One T-piece ordered
Tim
Mar 24, 2008 20:36:18 GMT
I know that when they were building a homebrew X-flow turbo in RF they used a return straight to the sump.
The thing i always wondered about was ensuring that you had enough oil pressure at the head if you were diverting some of it away for the turbo - high pressure oil pump solve this?
Mar 24, 2008 20:39:53 GMT
turbo doesn't use huge ammounts of oil, sometimes its nesecary to fit a flow restrictor. straight as possible return route is needed, and enter above the level of oil in the sump.
Mr K
Mar 24, 2008 21:09:01 GMT
the SS1 1800T uses a nissan silvia 1.8T, the oil feed from that comes from a T peice on the oil pressure sender and thats as nissan built it! so again, the answer would be a yup!
Last Edit: Mar 24, 2008 21:17:20 GMT by Mr K
Mar 24, 2008 21:36:05 GMT
metro turbo use this method as for the drain weld in a tube in to the sump
Mar 24, 2008 21:38:22 GMT
What you doing for your turbo oil drain then? Quite important to get that right or you'll start losing oil into the inlet or exhaust tracts past the turbo seals.
Mar 24, 2008 22:16:29 GMT
What you doing for your turbo oil drain then? Quite important to get that right or you'll start losing oil into the inlet or exhaust tracts past the turbo seals. From an old copy of Classic Ford, the editors Corsair is being fitted with a TT pinto. There is a pic of the engine out of the car from the exhaust side, the drain pipe from the turbo leads to the back of the engine block. On my 205 block there is a blanking bolt there. I plan to run the drain pipe to this hole. Said blanking bolt.........
harris66
drive it, break it, fix it and make it quicker!
Mar 24, 2008 22:20:37 GMT
our skylines use a larger diametre return pipe back into the sump, just a simple pipe but obviously above the oil level line, worth double checking if the return diametre is critical
1.2 corsa daily, 1.8t a4 avante, 6.3ltr austin a40....
Mar 24, 2008 22:28:42 GMT
Yeah loking at the size of that hole i'd say you might be better off with a pipe welded into the sump.
Mar 24, 2008 23:41:01 GMT
Yeah loking at the size of that hole i'd say you might be better off with a pipe welded into the sump. Suggestion taken on board. Will mull it over to night, think your probably right, I could make the return directly under the turbo too. For the best possible return.
Mar 25, 2008 10:29:52 GMT
The return from a turbo is only really helped by gravity so it must be lower than the level of the turbo and as least restrictive you casn get it.....which means the bigger dia the better.
I used a t piece off the pressure sender on my turboed fto with little or no pressure loss at all.
