luckygti
I need to try harder!
Mar 17, 2008 18:49:34 GMT
Ok, have to put the pug back together a bit sharpish as I'm on the move workwise and will only be at home weekends thus cutting down the amount of time I'll have for "tinkering"!! On top of everything else I need to fit the poly bushes I've bought for the front wishbones. Rather foolishly got a garage to remove the old ones but thought the new ones would be easy to fit!!!! They ain't!! Anyone got any tips??
Fitting Poly Bushesstealthstylz
@stealthstylz
Club Retro Rides Member 174
Mar 17, 2008 18:52:09 GMT
Just wind the nut in and it'll pull it in, maybe a bit of washing up liquid for lube. Matt
RetroMat
Column Shifting!
Mar 17, 2008 18:52:54 GMT
I used a clamp and an old socket to push a new bush in my triumph suspension
Last Edit: Mar 17, 2008 18:53:40 GMT by RetroMat
Mar 17, 2008 18:57:00 GMT
washing up liquid ftw.....
I have a variety of bush tools / big sockets/bolts etc, same method as Matt....
Mar 17, 2008 19:07:51 GMT
Do you know anyone or a friendly garage with a press?
205 GTi Mi16
205 XS - Now in filmidget's signature
Clio dci 80
I've found in life if someone is an idiot, they generally stay and idiot.
Mar 17, 2008 19:09:49 GMT
White grease rather than washing up liquid as it won't speed up the corrosion of the metal
luckygti
Mar 17, 2008 19:22:53 GMT
Excellent, thanks guys. I'll give it a bash first thing tomorrow!!
@stealthstylz
Mar 17, 2008 19:38:15 GMT
Good thing is once you make the tool i've shown you can use it again and again.
Matt
Mar 17, 2008 19:43:50 GMT
Big socket into little socket with a bench vice worked for me with all but the toughest ones. For that I had to construct a fabled device that is known only as "The Machine". Basically, I made a cone shape by curling a flat piece of metal and attached diminishing sizes of hose clamps down this to ensure it didnt give - then its the old "loads of lube and plenty of thrusting" technique. Oh! Suit you sir!
Last Edit: Mar 17, 2008 19:45:31 GMT by leigh
Mar 17, 2008 20:07:36 GMT
I found a vice was the only thing that made this from anightmare job to a bearable job. It's horrible.
