andyborris
The dash panel in the Land Rover is a mess, holes and a random mis-match of switches.
So I'd like to replace it with just a flat panel which will carry a 85mm speedo, 52mm fuel gauge, 7 Lucas style flick switches, 2 rotary switches, 1 push button and a choke knob and that's it.
Just wondering if anyone might have any ideas to "jazz" it up a bit? Bear in mind it's a Series 3 Landy and I've got very limited facilities (basically a battery drill!).The dash section for this is 37cm wide and 18cm high and I guess because I can't do anything apart from make holes, it'll be a pattern of the switches and gauges.
I've done a couple of designs myself, but they're pretty boring.
Thanks
andyborris
Might add an extra 52mm gauge...
Might add an extra 52mm gauge... Given the history of this one, temp?
andyborris
Would brushed or engine turned aluminium be a suitable look? I’ve done brushed aluminum with a sanding block, but never tried turning.
andyborris
More thinking about the actual layout of switches and gauges. All the layout designs I've done just seem a bit boring, but maybe a flat sheet with a couple of gauges and 9 switches will always be boring if it's going to be usable?
andyborris
Mar 14, 2024 15:53:02 GMT
Did this.
v8ian
Mar 14, 2024 18:00:41 GMT
I was just about to suggest a P5B dash and pods
andyborris
Mar 14, 2024 18:15:21 GMT
I was just about to suggest a P5B dash and pods Thanks, that's a really good call, might do that later.
