Paul Y
Jan 24, 2024 14:51:16 GMT
Hello! My google-foo is weak and I can't seen to find this number anywhere on line. Do any of you rather intelligent gentlemen happen to know the combined CFM of the fans from a Mk1 Focus - if it makes any difference an 00-04 2litre. Thanks, P.
They were usually different for manual vs auto and with and without Aircon, I don't ever remember Ford talking about CFM it was always the power that was used to differntiate them and internaly to Ford the flow even back then was done as a system using CFD.
The ones fitted with air con moved a lot of air, they would have been sized to drag a large caravan up something like Grossglockner with the aircon on.
Last Edit: Jan 25, 2024 9:58:40 GMT by kevins
Paul Y
Jan 25, 2024 11:40:12 GMT
Thanks Kevin, It would appear that a lot of the Corvette chaps utilise a 2.0 AirCon equipped Focus fans to cool their turbo LS engines - was more out of curiosity. Thanks of the reply. P.
Paul Y
Jan 25, 2024 14:01:01 GMT
As an update just been given the CFM for a 2.0 auto with AC Focus fan set up just in case anyone else is looking Its 2500CFM at 50amp draw P.
