Oct 10, 2023 16:56:42 GMT
I have one of these guns i bought it for applying dinitrol, but when i use the gun it either just lightly spatters out of the lance, or dosnt come out at all. i take it this gunis designed for this type of stuff? I have warmed it up too. any one got any tips for applying it? t thanks
bricol
The nozzle with the thing sideways slits, not the bent pipe thing?
It does have to be thin enough to pass through the slits, so it needs a good shake/stirring, maybe even thinning.
The trigger is two stage - I think opens the liquid valve, then the air - so you might need to adjust the screw in the handle to allow the trigger to come back far enough.
You do need enough air, both pressure and flow - I don't think I've had much success with the recommended air pressures, I simply use it at just about full pressure from my compressor - 90 psi?
If you've taken it apart to clean, check the arrangement of seals compared to the instruction sheet vert carefully - I lent mine out, he kindly cleaned it - but missed/lost a seal, so it starts up as soon as the air is connected. I will eventually get round to fitting the spare seals that come with it.
I've done this recently with my Discovery. I thinned it down with white spirit. The tin suggested up to 10% but I found it needed a little bit more.
Oct 11, 2023 11:24:00 GMT
sticking it in bucket of hot water can help too.
slater
Club RR Member Number: 78
dinitrol and sealey gunslater
@slater
Club Retro Rides Member 78
Oct 11, 2023 15:37:14 GMT
Which dinitrol? Cavity wax I assume? Warmed up it should be very 'thin' so if it's not there's somthing amiss there.
Must admit I've never used a gun like that. Always seemed a waste of money when a 20quid shultz gun does the same thing.
Oct 11, 2023 22:25:56 GMT
the sealey gun is good mate, it works well, defo worth the money. Phoned Frost today, and they said the 3125 is designed as a high solids, use a shultz gun or the sealey one with out the tube on it. for chassie legs use the ml.
thanks for the help
