Sept 21, 2023 19:17:46 GMT
I have taken this out of 60's kit car, but I don't know if it is from a classic or more modern car. Approx. dimensions are 570mm Width x 570mm Length x 150 to 120mm Depth. Fuel Inlet Pipe is 50mm dia. It looks similar to the MGB fuel tank, but the fuel sender is in the wrong location. It's in good nick so I want to sell it on to someone who actually needs it. Has anyone got any idea what car it is for? TIA
Sept 24, 2023 15:58:22 GMT
Cheers! I think you might be right. It certainly looks the same. I will find & check the ford dims and see
Sept 24, 2023 17:00:11 GMT
Yes I agree Cortina it forms part of the boot floor. Trivia - The unpunched second filler pressing is so that it can be used for the Corsair.
Colin
Last Edit: Sept 24, 2023 17:00:28 GMT by colnerov
Sept 24, 2023 19:24:50 GMT
Cheers. Yes, it definitely looks exactly like the Mk1 Cortina. Useful to know it can also be used for the Corsair. Not sure whether it is the same as the GT? All good info thanks and it means I will be able to pass this on to someone who really needs it for it's OEM purpose
