Darkspeed
Club RR Member Number: 39
Boosted Pinto.Darkspeed
@darkspeed
Club Retro Rides Member 39
Sept 18, 2023 18:37:34 GMT
As far as the car itself goes, to make it a little less abstract, Think of a road track car (a regular circuit, but also usable for shorter tracks, and/or hillclimbs), front/ mid engined, about the weight distribution of a Formula Ford, and about the wheelbase of a Austin Healey Sprite. In other words, small and light... Which makes me think of Morphed with this With a dose of - Because what else you going to do with that spare foot Fiddle brakes
Sept 18, 2023 19:08:56 GMT
As far as the car itself goes, to make it a little less abstract, Think of a road track car (a regular circuit, but also usable for shorter tracks, and/or hillclimbs), front/ mid engined, about the weight distribution of a Formula Ford, and about the wheelbase of a Austin Healey Sprite. In other words, small and light... Which makes me think of Morphed with this With a dose of - Because what else you going to do with that spare foot Fiddle brakes Darkspeed , yep... Can't fool you. Its an old Clubmans racer... ( you even found a rare pic of a Pinto powered Mallock) Edit: BTW, for the people who know my cars. No, I'm not doing this to my Mallock U2 Mk6...
Sept 18, 2023 19:14:04 GMT
If it Helps MS , i built a clutched automatic for my tvr in the early 90's .
I used a c4 , and fitted a b and w transpak , this gave a choice of shift ferocity, i went for the middle setting , and i can definitely say shifting on boost in any gear felt like something had just run into the back of the car .
off boost it was gentle .
i had 3 manual gears i could select with my foot flat down ,and no clutch needed .
a drawback was the 2.3:1 1st gear was too high, when drag racing on treaded tyres i found some 23'' tall tyres to lower gearing , a good point was i could burn out at whatever rpm i liked .
i drove it on the street like this for a while , i liked it , however i could tell less power was available compared to the manual box .
the video on my youtube channel of the tvr in green running a 12s run was with this box.
i still have it if you want any pictures of it .
regards robert
Last Edit: Sept 18, 2023 19:16:36 GMT by ivanhoew
Sept 18, 2023 19:21:07 GMT
If it Helps MS , i built a clutched automatic for my tvr in the early 90's . I used a c4 , and fitted a b and w transpak , this gave a choice of shift ferocity, i went for the middle setting , and i can definitely say shifting on boost in any gear felt like something had just run into the back of the car . off boost it was gentle . i had 3 manual gears i could select with my foot flat down ,and no clutch needed . a drawback was the 2.3:1 1st gear was too high, when drag racing on treaded tyres i found some 23'' tall tyres to lower gearing , a good point was i could burn out at whatever rpm i liked . i drove it on the street like this for a while , i liked it , however i could tell less power was available compared to the manual box . the video on my youtube channel of the tvr in green running a 12s run was with this box. i still have it if you want any pictures of it . regards robert Yeah, any pics and extra info would be great... Feel free to post them on this tread, since I'm still in the info gathering/ planning stage, and not actually building yet. BTW, that goes for anybody who has info and/or thoughts to add. I really appreciate you guys thinking with me.
Sept 18, 2023 20:29:09 GMT
I mean, this isn't normally the sort of car we discuss around these parts, but the Koenigsegg Regera did away with the transmission and uses only a torque converter, and that doesn't seem to be unduly hampered by sluggish acceleration. If anything, it's quite nippy. Clever idea I thought. If he can do it....
Last Edit: Sept 18, 2023 20:30:07 GMT by horrido
v8ian
Sept 18, 2023 20:44:32 GMT
Daf style transmission might be another way, constantly variable, ford made smaller compact version for the fiesta? torque converter driving a Variable trans?
Sept 18, 2023 21:29:34 GMT
horrido and v8ian, thank you guys. That is exactly the kind of feedback I'm looking for. If we'd make this the weird and unusual transmission thread, I'd be totally OK with that... And then, when the time comes, it will become a buildthread for my little racer...
Sept 19, 2023 1:35:24 GMT
Nothing wrong with the 3½ gears you get with a Powerglide.
Particularly if you use a converter with a lockup clutch and control that...
Sept 19, 2023 5:21:14 GMT
Looking for that Mallock U2 Mk6 I found a little story in germanys leading car mag auto, motor und sport. It was about a car purchased by a german in the netherlands. It was left by an almost two metres tall dutchman who went to the USA in the 90s. Was that You metalshapes? The car got stolen later, then found and finally it landed in an auction. Here is the link, I know You can read some german.
spacekadett
F*cking take that Hans Brrix!!
Sept 19, 2023 6:45:49 GMT
Daf style transmission might be another way, constantly variable, ford made smaller compact version for the fiesta? torque converter driving a Variable trans? They did. From memory it used a peculiar metal belt that pushed rather than pulled, although I can’t remember much more without digging out one of my old books. I do remember that they could be interesting to drive; some would literally launch when you selected drive, almost to the point of stalling the engine, just what you need in a car usually driven to little old ladies 😂
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Darkspeed
@darkspeed
Sept 19, 2023 6:58:42 GMT
I will have to try and remember to have a chat with my mate Roy - He told me story about Spen King, a large capacity tuned Rover V8, a Westfield and a torque converter. I'm sure he said that it just had the one speed.
Can well believe it as my G27 only really needed 5th once you were rolling.
ETA
The CTX - My mum was about to buy one when I convinced her to buy a second hand VW Golf GL convertible Auto instead.
Last Edit: Sept 19, 2023 7:04:05 GMT by Darkspeed
Sept 19, 2023 7:50:23 GMT
Looking for that Mallock U2 Mk6 I found a little story in germanys leading car mag auto, motor und sport. It was about a car purchased by a german in the netherlands. It was left by an almost two metres tall dutchman who went to the USA in the 90s. Was that You metalshapes ? The car got stolen later, then found and finally it landed in an auction. Here is the link, I know You can read some german. I'm tall ( not quite 2 metres, though), from the Netherlands, and moved to the States in the '90s. ( so parallel lives, or they borrowed some of my history... ) But that is not my car. ( cool article BTW) I took mine with me, and I still have it. I bought it from a racecar dealer in Dover in the '80s. Here is a pic he took of me, the first time I sat in it. And here is a pic of Arthur Mallock, working on my car. And a more recent pic.
v8ian
Sept 19, 2023 8:01:42 GMT
Mk6 mallock?
mylittletony
Club RR Member Number: 84
Boosted Pinto.mylittletony
@mylittletony
Club Retro Rides Member 84
Sept 19, 2023 8:02:34 GMT
Ah I'm enjoying this thread already - there's nothing quite like creative engineering applied to making cars fast. Darkspeed, what's this? Any more info??
Sept 19, 2023 8:08:28 GMT
Ah I'm enjoying this thread already - there's nothing quite like creative engineering applied to making cars fast. Darkspeed, what's this? Any more info?? That is a Mallock U2, probably the only one that was street legal in Germany. You can see this left of the plate, on the rear of the car.
Sept 19, 2023 8:20:02 GMT
Yes, my Mk6. But that is not the car this thread is about. The one this thread is about is a Clubmans racer ( not a Mallock) , a much later version ( more aero, rear wing/ high downforce nose/ sidepods), in need of a full resto. Hopefully, if everything goes well, it will end up looking a lot like this one.
v8ian
Sept 19, 2023 8:32:53 GMT
Arthur Mallock------- the other Colin Chapman,
Looking like the mallock above....... BDA powered too,
Last Edit: Sept 19, 2023 8:34:36 GMT by v8ian
93fxdl
Enter your message here...
Sept 19, 2023 8:35:13 GMT
Slightly different take on the idea, How about automating a manual box Use standard clutch for pulling away and stopping Use solenoids to control the shifts, with ignition cut to allow the gears to move Ttfn Glenn
Boosted Pinto.stealthstylz
@stealthstylz
Club Retro Rides Member 174
Sept 19, 2023 12:10:05 GMT
I'll try and dig some photos out of a Pro Stock turbo Pinto head out we had at work when I get chance. Was a absolute work of art, made 500+hp with blow through Dellorto's.
npp
Sept 19, 2023 12:16:47 GMT
when whas the pic taken?
The car is registered in Hagen, where I lived from 1980-88 and 1998-99, and the registration HA-TZ forms the German word for chase or hustling along. I've never seen the car on the road though.
Last Edit: Sept 19, 2023 15:25:31 GMT by npp: typo
