MiataMark
Club RR Member Number: 29
brake bleedingMiataMark
@garra
Club Retro Rides Member 29
Sept 3, 2023 11:21:52 GMT
Rich
Club RR Member Number: 160
brake bleedingRich
@foxmcintyre
Club Retro Rides Member 160
Sept 3, 2023 11:31:01 GMT
A vacuum oil extractor is fine to draw brake fluid through provided the device is compatible with brake fluid. Those cheap vacuum guns are just that. Most of them don’t work properly out of the box and the minute they get brake fluid near the seals in the pump they fail.
Last Edit: Sept 3, 2023 11:31:57 GMT by Rich
brake bleedingbrachunky
@brachunky
Club Retro Rides Member 72
Sept 3, 2023 11:44:41 GMT
Can't comment if applicable to your wheels but on many vehicles, once the m/c has had air in it, bench bleeding the m/c will is essential to getting a consistent "feel"
MiataMark
@garra
Sept 3, 2023 12:54:50 GMT
Umm, for the oil extractor it does say suitable for oils or similar NON-corrosive fluids, which I guess rules out brake fluid. Might have to get SWMBO involved again.
Sept 3, 2023 17:07:31 GMT
Its usually easier with two people, personally I use a Gunsons pressure bleeder, usually works fine on my own, cheaper ones are available but to be honest its worth the extra.
It will come in handy even if you never use it
