jimi
Aug 28, 2023 14:10:44 GMT
Thanks 👍 It's there and it works, that's the important thing 👌
Last Edit: Aug 28, 2023 15:59:08 GMT by jimi
Aug 28, 2023 17:08:17 GMT
I’m not having much luck with this new layout. Today I’ve written a post and added pics. Every pic had a grey line across it but I thought that would be ok, but when I pressed create thread it says I must provide a message, and won’t go any further. I would upload a screen shot but it won’t let me because of the above issue.
Aug 28, 2023 18:20:10 GMT
OK Now on my other laptop (also Windows 10 and Firefox) the side menu overlays on top of the main window so I can't read the left side of it
misteralz
Aug 28, 2023 18:40:08 GMT
I’m not having much luck with this new layout. Today I’ve written a post and added pics. Every pic had a grey line across it but I thought that would be ok, but when I pressed create thread it says I must provide a message, and won’t go any further. I would upload a screen shot but it won’t let me because of the above issue. Yep, that happened to me as well. I'm just going to avoid adding pics until it's all calmed down.
Aug 28, 2023 18:58:19 GMT
Click the menu button on the top left.
Aug 28, 2023 20:05:21 GMT
Bloody hell its a good job I don't work with tech for a living...
Aug 28, 2023 20:47:39 GMT
This and @miseralz is proving hard to diagnose because every browser and device I've got here and tried it on as worked fine.
The grey bar across is the progress bar (it gradually goes blue as an image uploads and then disappears). If it is staying grey then it seems it isn't starting the upload. The code for the upload is the same as the old code, it is initiated in a different way, but that code is the same for everyone so it should either work, or not, for everyone.
Apologies if you've told me already, but browser and device from both of you would be useful. If I can repeat the issue I can solve it, the problem with this one is repeating the issue.
misteralz
Aug 28, 2023 22:38:05 GMT
Desktop site but on mobile, Samsung S20FE and Firefox. Picture uploading has always been hit or miss, and I'd usually highlight and copy all my text before uploading pics as I'd often have to refresh it a few times before it played ball.
Aug 28, 2023 22:41:54 GMT
Hi Hotwire. I’m using an iPhone with what ever browser it comes with. I updated my thread fine yesterday after I rewrote it without the quote. It does also say “switch editor” next to the create thread button, but that doesn’t appear to do anything
v8ian
A little glitch I have come across this morning, I posted a comment, then thought I wanted to add a bit more, so went to editor and the edit box was blank, it dosent seem to retain your post you want to edit, so I had to rewrite it.
jimi
Edit works fine for me, can see see/edit the existing text and switch to the plain text editor Chrome on Android
EDIT just tried what you did, no problems 👍
Last Edit: Aug 29, 2023 10:03:36 GMT by jimi
v8ian
not sure why it happened, I tried twice, but there was an external link attached to the post.
@hotwire
Still can't edit my own posts ...
Laptop 1920x1080, win 11 pro 22H2, Firefox ...
HoTWire" Still can't edit my own posts ... Laptop 1920x1080, win 11 pro 22H2, Firefox ... " ...and what does /is "switch editor" supposed to do ? HoTWire here... seems I can edit the post, so it isn't the content of the post that is the issue. I wonder if there is an error in the code before the edit box is populated, which stops it being populated, so the error is elsewhere. Although I'm doing this in Chrome... so let me check in Firefox
Last Edit: Aug 29, 2023 9:05:56 GMT by HoTWire
Thanks for the updates v8ian westbay jonsey and misteralz ... seems the post edit is acting up. The "Switch Editor" thing should move between the text only BBCode version, and the full fat new editor (it starts in the new editor state). Let me get to the bottom of the editing issues, that'll likely be the only thing I manage today as I've got a very full day at the day job and suspect I'll need some time away from screen at lunch.
westbay ... it is a Firefox based issue, now I can repeat it I can resolve it .. I wonder also if maybe the image upload failing is related (I hope it is as that will make it easier to fix )
jimi
Aug 29, 2023 10:31:32 GMT
I normally use Firefox for all browsing but I switched to Chrome for browsing Retro Rides last year after some problems with FF on here ( can't remember what). I feel that sadly Firefox has gone downhill in the last couple of years with some very unpopular changes.
For info: I just tried editing using Brave, Firefox, Chrome, DuckDuckgo and Edge Canary, all on Android and Firefox was the only one that didn't work.
Aug 29, 2023 12:27:38 GMT
selected edit post as peoples had mentioned problems posting, and it gave me a big empty box. so heres the post i wanted to edid copy and pasted below. where i would have added edit test passed but it Failed! Posted by SilverMachine29 minutes agoi like it, although the burger menu was open when i logged in which did confuse me for a while( it was covering 1/3 of the left side of the side - so my name was showing as erMachine - until i realised to close it! for reference I'm using firefox 116.0.3 (64-bit) Mozilla firefox snap for Ubuntu. Canonical-002 - 1.0 Ubuntu 22.04 - (i need to update to 23.04!)
2006 Audi A3 2003 Fusion 2 looking for a project....
Aug 29, 2023 13:01:49 GMT
so yes it had deleted my original post, good job i copied and pasted it!
