Aug 22, 2023 18:03:38 GMT
I will shortly be in a position to cover the Midas' dash top with scrim foam and vinyl.
As it will have heater pipes and vents, and will sit in the sun, a hi-temperature spray on glue is essential.
What do you recommend?? I have only used brush on impact adhesive in the past.
Aug 22, 2023 19:30:24 GMT
at200
Aug 22, 2023 22:45:17 GMT
I used the same for my Saab headlining. Only a year or so but still OK. It's the brand I see recommended most on various forums.
Hi-temp Spray Adhesive. ChasR
@chasr
Club Retro Rides Member 170
Aug 22, 2023 22:56:49 GMT
Glues from AS-Trim are pretty good, and are glues with most trimmers will use.
The Hi temp stuff is trickier to work with, as it doesn't lay down as well, but it is stronger.
I used the same to stick the trim back together on my range rover still fine after 4 years.
Aug 23, 2023 12:14:05 GMT
Excellent - very much appreciated guys!
