Aug 16, 2023 15:45:09 GMT
Hi All Anyone have any suggestions please I'm after 1 metre of 16mm threaded rod with a 3.0 pitch, Anyone know a supplier ?? Thanks, Nigel
jimi
Aug 16, 2023 19:30:36 GMT
Are you sure of the pitch ? Can't remember ever coming across 16 x 3 IIRC fine pitch is 1.5 and coarse pitch is 2mm
Aug 16, 2023 19:38:52 GMT
These are really coarse, I measured them on a thread guage, came out as 3.0, I'd actually already bought a metre of 16mm at 2.0 pitch but it's too fine, Nigel
Last Edit: Aug 16, 2023 19:39:46 GMT by Alpina99: Misspelling,
Aug 16, 2023 20:35:08 GMT
That's the sort of pitch that lead screws come in. Are you sure it's not a trapezoidal thread?
Aug 16, 2023 23:19:58 GMT
Sorry, what's that ?? It's to replace the "drive screws" on a set of adjustable ramps,one sheared, Nigel
jimi
That will almost certainly be a lead screw, (not a standard metric thread like threaded rod) en.m.wikipedia.org/wiki/Leadscrew May well be specific to the ramp manufacturer.
Jimi and Crockpot, Many thanks for your help, Nigel,
Aug 18, 2023 12:08:03 GMT
search this on ebay should bring up what you need
T14 to T20 Trapezoidal Screw Rod Nut, Pitch / Lead 3mm 4mm, Long 150 - 600mm Cut
looks like they are all from china though
maybe a lathe supply place may hold some
redratbike, thanks for that, Is that the same type of thread.then ?? Nigel
v8ian
Aug 19, 2023 10:09:26 GMT
The other thing to check if its Buttress or Acme, Buttress is tapered on one side and is semi self locking, Acme is square form.
Aug 19, 2023 10:30:05 GMT
Thanks Ian, I think I'd be better off going to an engineering company to see if they could cut one, Nigel
