I have just bought a CLARKE 3HP SINGLE PHASE 2-POLE MOTOR (230V) Product Code 010210465 . but as it came with no wiring instructions so i am a little stuck . I have connected the yellow/green to the motor body as indicated with the earth symbol with securing screw provided, and the blue cable to the cut out switch as per my old motor set up but not sure which terminal to connect the brown also i need it to run anti-clockwise. Any help would be much appreciated.
slater
Club RR Member Number: 78
Clarke compressor motor wiring slater
@slater
Club Retro Rides Member 78
To be honest best bet is to do some googling and watch a few youtube videos and teach yourself how it works. It's not that complicated but there's different types of single phase motor so first thing to identify what you've got. It looks like it will be a start/run style motor with two capacitors and a centrifugal switch?
Thanks for your reply . Yes it has the 2 capacitors i have attacked these further pictures i cannot seem to find anything matching to copy it from
jimi
Is that image is from your new motor ?
Last Edit: Aug 6, 2023 16:58:08 GMT by jimi
Is that image is from your new motor ? [/quote] Yes it is inside the plastic lid
jimi
It's showing you how to connect it and which way the links should be for D.O.R Have you moved the links ?
No the links are exactly how it came
slater
@slater
The links are set for it to run counter clockwise.
Looks like all you need to do is connect live to one of the linked terminals and nutural to the other. Everything else is done for you by the look of it.
I have attached the Nutural to the cut out switch which follows to the terminal where the yellow is. its a case of where the live (brown) goes the same or the adjacent link?
i see Now .. many thanks for your help
Just to Update .. it is now all up and running thanks again for all your help
Evening all
So does the neutral need connecting to the cutoff switch ?
Thank you
jimi
It won't matter, either neutral or live will work.
It will work either way but convention dictates that you should always break the live not the neutral (unless breaking both at the same time) so that the point where power is isolated is the last place that voltage is present.
jimi
Dec 23, 2023 14:09:27 GMT
It will work either way but convention dictates that you should always break the live not the neutral (unless breaking both at the same time) so that the point where power is isolated is the last place that voltage is present. Indeed you should always switch the live I forgot there was a thermal trip in the circuit
