My older Sealey sa2120 3hp has finally given up its 2nd motor since i have had it , (the second motor was a £99 Chinese replacement that has lasted a couple of years). It has been powered by my honda Gx 7kva Generator which has been pretty useful as a hardwired power point is quite some distance away.
I am looking to purchase a CLARKE XE18/200 (OL) 18CFM 200LITRE 4HP INDUSTRIAL AIR COMPRESSOR (230V)
Technical specification
Motor (HP) 4.0
Watts 3000 W
Air Tank Volume 200 Litres
Air Displacement 18 cfm
Max Working Pressure 145/10 psi/bar
Oil/Oil Free Oil
Input Voltage 230 V
Wheel Mounted No
Volts 230 V
This air compressor must be run from a 40 Amp supply minimum.
Does anyone have any reviews on this model ? and Thoughts to My generator powering it .
Many thanks in Advance
Motor (HP) 4.0
Watts 3000 W
Oil/Oil Free Oil
Input Voltage 230 V
Wheel Mounted No
Volts 230 V
