After some months away from the car it now idles near 1500 (as opposed to below 1000)
I was losing brake fluid into the servo which i thought may have created a vacuum leak but i have replaced the servo with no difference to the idle
The two SUs appear to be closing fully. If i look past the piston they both appear shut. The choke cable isn't staying on
I've sprayed carb cleaner all around the carbs and hoses and inlet manifold and can't get it to change tone. I thought i had something initially but cleaner was just finding its way through the main intake
I did take a video of it though
