Hi, in the process of getting my interior re done, the trimmer said if I strip the door cards it will have me labour costs etc, so pulled the old material off which has been glued in the past,
I need to make a new panel which the trimmer will re cover, what came off looks to be very thin plastic with foam on it, does anyone know where I can get a sheet of this stuff, or what would be good to use instead, I thought 1mm plywood or something possibly might work
Thanks Paul.
Thanks Paul.
