Apr 10, 2023 12:46:20 GMT
My little jet has had a prefacelift front end fitted so no longer has the front corner clear indicators. Do I need to add side indicators to the door area or are they not needed? Currently have indicators stuck under the mirrors & I hate the look.
Last Edit: Apr 10, 2023 12:46:45 GMT by ianlea73
zeberdee
Club RR Member Number: 2
Laws on side indicators zeberdee
@zeberdee
Club Retro Rides Member 2
Apr 10, 2023 12:57:47 GMT
Mot manual is your friend . www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehiclesVehicles first used on or after 1 April 1986 must be fitted with an amber side repeater indicator on each side. The side repeater can be part of the front direction indicator if it has one of the following: a wraparound lens marked either with an ‘E’ mark in a circle or an ‘e’ mark in a rectangle with a number 5 above it an amber light coming through the front lens when viewed from 1m to the side of the rear bumper
Last Edit: Apr 10, 2023 12:58:38 GMT by zeberdee
Rich
Club RR Member Number: 160
Laws on side indicators Rich
@foxmcintyre
Club Retro Rides Member 160
Apr 10, 2023 13:02:04 GMT
You can be a bit naughty on this, and have an additional wire set for side repeaters and plug them in for the mot and stick them to the doors with strong magnets. Once a year lights. 😉
Apr 10, 2023 13:59:41 GMT
Something here? (Mad photoshop skills for hire!)
Apr 10, 2023 14:00:19 GMT
The critical point here is the date of introduction of the side repeater legislation, in this case, 1st April 1986. The vehicle in question is clearly bearing a registration number that dates it between August 1st 1980 and July 31st 1981. Even if it's a grey import or some such, this will be an age related plate.
So it doesn't NEED side repeaters to be legal!
Question answered?
Steve
Darkspeed
Club RR Member Number: 39
Laws on side indicators Darkspeed
@darkspeed
Club Retro Rides Member 39
Apr 10, 2023 14:27:03 GMT
So it does NEED side repeaters to be legal! Question answered? Steve FTFY - Getting your Suffix and Prefix mixed. That W is a 2000 plate - repeaters required
v8ian
Apr 10, 2023 14:51:00 GMT
Personally. I would just leave as is, if a tester gets a bit out of his pram fit some small ones under the mirrors, normally its not in their remit to give you grief, generally, if its not fitted they don't notice...... if its there it has to work.
Apr 10, 2023 14:54:40 GMT
Something here? (Mad photoshop skills for hire!) Great skills & good idea too.
Apr 10, 2023 14:55:37 GMT
Personally. I would just leave as is, if a tester gets a bit out of his pram fit some small ones under the mirrors, normally its not in their remit to give you grief, generally, if its not fitted they don't notice...... if its there it has to work. My guy is very helpful but I don't want to take the Mickey, I'll have a chat with him & test the waters.
Rich
@foxmcintyre
Apr 10, 2023 16:18:27 GMT
Maybe use a Mk2 golf smoked front indicator assembly mounted below the door in line with the front spoiler? Invisible, cheap if damaged, can be permanently installed and won’t spoil the look/make the spoiler look more integrated?
Apr 10, 2023 16:33:31 GMT
Many years ago I had a 306 s16 , had the in wing side repeaters welded and filled etc ( along with the door locks) first MOT it was set to fail as the examiner jumped to the conclusion that they were required , but as stated above I had the correct e marking on the headlamps so after a brief conversation and a quick check of his very big MOT book the car came away with a clean ticket
Rich
@foxmcintyre
Apr 10, 2023 16:58:06 GMT
Many years ago I had a 306 s16 , had the in wing side repeaters welded and filled etc ( along with the door locks) first MOT it was set to fail as the examiner jumped to the conclusion that they were required , but as stated above I had the correct e marking on the headlamps so after a brief conversation and a quick check of his very big MOT book the car came away with a clean ticket Technically I would think the 306 doesn’t ‘fit the bill’ to be exempted from the rules, certainly not by todays standards. (Without having one to look at Vs the test wording I can’t be sure 🤣) But I don’t disagree with having a go and seeing how it fairs without come test time
longman
Laws on side indicators longman
@longman
Apr 10, 2023 17:01:53 GMT
I had the side repeaters removed from the wings on my late 86 911 , never failed an MOT in the 15 years I had it..
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
Apr 10, 2023 17:02:46 GMT
Maybe use a Mk2 golf smoked front indicator assembly mounted below the door in line with the front spoiler? Invisible, cheap if damaged, can be permanently installed and won’t spoil the look/make the spoiler look more integrated? Would match the splitter. I'll have a look at some images. Thanks.
Apr 10, 2023 17:09:43 GMT
Many years ago I had a 306 s16 , had the in wing side repeaters welded and filled etc ( along with the door locks) first MOT it was set to fail as the examiner jumped to the conclusion that they were required , but as stated above I had the correct e marking on the headlamps so after a brief conversation and a quick check of his very big MOT book the car came away with a clean ticket Technically I would think the 306 doesn’t ‘fit the bill’ to be exempted from the rules, certainly not by todays standards. (Without having one to look at Vs the test wording I can’t be sure 🤣) But I don’t disagree with having a go and seeing how it fairs without come test time I wasn’t sure either but the old phase1 headlights had the correct marking according to the testers manual to not require them Bloody good job as I’d of needed new wings to get the holes back
Rich
@foxmcintyre
Apr 10, 2023 18:00:09 GMT
Technically I would think the 306 doesn’t ‘fit the bill’ to be exempted from the rules, certainly not by todays standards. (Without having one to look at Vs the test wording I can’t be sure 🤣) But I don’t disagree with having a go and seeing how it fairs without come test time I wasn’t sure either but the old phase1 headlights had the correct marking according to the testers manual to not require them Bloody good job as I’d of needed new wings to get the holes back The e marking isn’t what makes them compliant. It just means they are approved for being lights for the EU market. Having the E mark just proves they aren’t some weird lashup. If you read it it has to be a wraparound lens with An E approval stamp. The 306 lamps aren’t wraparound. But moot, as you got your MOT
Last Edit: Apr 10, 2023 18:02:20 GMT by Rich
Apr 11, 2023 18:42:53 GMT
OOPS!
Steve
Not sure why you'd want to delete something that has the potential to save your life. With the amount of idiots "driving" around nowadays I would have thought that clear and visible indicators should be considered essential items.
Apr 12, 2023 11:22:51 GMT
Not sure why you'd want to delete something that has the potential to save your life. With the amount of idiots "driving" around nowadays I would have thought that clear and visible indicators should be considered essential items. You are 100% correct, of course. Buuut, the idiots where I live won't see indicators unless you fit them to their bloody phone screen! Lost track of the numbers of people swiping and texting while driving
mrbig
Semi-professional Procrastinator
Apr 12, 2023 13:33:14 GMT
1969 German Look Beetle - in progress
