andyborris
Only need a couple of sizes for a Rover V8 engine, can only find big sets at £90 and up!
Any leads or do you have some I could borrow for a day or so? I'm Kent.
Thanks
v8ian
What size?
bricol
Just buy the UNC taps you need separately - if you aren't actually cutting threads, just chasing, then carbon steel will do.
I would go for HSS personally, then if you do need to use them properly, then you can.
UNC Internal Thread Chasersstealthstylz
@stealthstylz
Club Retro Rides Member 174
As above. Just buy a couple of bottoming taps the right thread and use those. They're a lot better than thread chasers.
v8ian
let me know what you want, I'm in Hastings.
mk2cossie
Club RR Member Number: 77
UNC Internal Thread Chasersmk2cossie
@mk2cossie
Club Retro Rides Member 77
Only need a couple of sizes for a Rover V8 engine, can only find big sets at £90 and up! Any leads or do you have some I could borrow for a day or so? I'm Kent. Thanks As said, what sizes? I have a set of UNC thread chasers for internal/external threads. May also have some UNC taps and dies for lending. I'm near Ashford if thats any help?
andyborris
let me know what you want, I'm in Hastings. Thanks, need 7/16 x 14TPI UNC and 3/8 x 16TPI UNC. Just want to clean the threads, I've been told that using a tap will cut and loosen the "grip" on the bolt? Not having much luck with this RV8 engine, some threads stripped as I fitted the inlet manifold to the heads. Have a spare set of heads, but will use studs this time and want to make sure both block and heads have good clean threads. Getting fed up with changing head gaskets ( third times the charm!).
andyborris
Only need a couple of sizes for a Rover V8 engine, can only find big sets at £90 and up! Any leads or do you have some I could borrow for a day or so? I'm Kent. Thanks As said, what sizes? I have a set of UNC thread chasers for internal/external threads. May also have some UNC taps and dies for lending. I'm near Ashford if thats any help? I'm in Ashford, as I said to v8ian need 7/16 x 14TPI UNC and 3/8 x 16TPI UNC. Won't be for a few days, waiting for parts to arrive from USA. However be nice to meet a fellow local RR'er!
andyborris
People on here are the best.
v8ian
Found a3/8 and 7/16 unc, one a 1st, ones a 2nd yours if you want them, no issue to grind the tip off so it will go deeper,
andyborris
Thanks everybody.
Took some advice, put a slot into a bolt and with some WD40, it worked a treat. Pulled out loads of c**p.
Now waiting for the head studs to arrive from the USA, (hopefully Friday) and then I'll have try number 4 at getting the heads to seal!
Been a bit unlucky with this one.
bricol
Apr 14, 2023 13:21:31 GMT
let me know what you want, I'm in Hastings. I've been told that using a tap will cut and loosen the "grip" on the bolt? Go back and ask how they think the thread was cut(or rolled) in the first place . . . There are classes of thread, allowing you to juggle clearances - you might want a tighter fit, or a looser fit to allow things to centralise on datum surfaces etc. But for general purpose use, a standard tap will be fine.
