v8ian
Mar 22, 2023 18:54:19 GMT
OK Guys, I want to replace the ever so noisy redtop pump on my Toledo, My specs are the need for it to be LOW pressure, (I'm on carbs at the moment,)
It needs to be QUIET,
It needs to be mounted under the car and as such needs to be waterproof
It needs to be as compact as possible too
And not be mega expensive......
pptom
Mar 22, 2023 19:31:39 GMT
Last Edit: Mar 22, 2023 19:37:17 GMT by pptom
Mar 23, 2023 20:57:13 GMT
Another vote for Huco.
Note they come in two flavours according to where you want to locate it.
Mar 27, 2023 19:55:40 GMT
Made in New Zealand I'm pleased to see, not China.
Mar 29, 2023 20:00:29 GMT
The facet ones are very depedant on how they are mounted, with soft rubber bobbins, a bit of flex in each hose and mounted to something solid (not the middle of a flat panel) they are not too noisy.
bstardchild
Club RR Member Number: 71
Recommend me a Fuel Pumpbstardchild
@bstardchild
Club Retro Rides Member 71
Mar 29, 2023 20:07:49 GMT
I used the original fuel injection pump on my 3.0 24V when I converted to carbs - just put used a pressure step down - facets I found way too noisy
v8ian
I used the original fuel injection pump on my 3.0 24V when I converted to carbs - just put used a pressure step down - facets I found way too noisy That is an option, regulate a FI pump I know. My plans for next winter is to Fuel Inject the car, the pump, Ideally wants to sit under the floor by the tank outlet, the Facet pump, is, at the moment mounted inside the boot, about 15'' higher than the bottom of the tank, thats a recipe for a noisy pump, and the boot stinks too, I'm going to stick with a low pressure pump, and when go to injection use the said pump as a lift pump for my swirl pot.
Last Edit: Mar 31, 2023 6:26:22 GMT by v8ian
