My mate built this last year but it still needed finishing off. He had it up for sale over Xmas with no takers, he then relisted it recently for a far fairer price. I'd just sold the del sol & I'm currently breaking my eunos mx5 so I'm always on the look out for projects. It needs an mot, a Misfire sorting & a good clean up. I'd say it's a 75%er. We did a deal which worked well for me so it's now mine. My plan is to redo the interior, including re trimming the seats. Remove the bed & strip the back half of the chassis & clean everything up. I plan on fitting pine slats & metal trim like the American pick ups but in the Yakisugi style of burnt wood & natural varnish. Anyway have a look & enjoy.
Last Edit: Mar 5, 2023 21:37:54 GMT by ianlea73
Gotta be worth it, just for the wheels and front bumper.
Love it.
Gotta be worth it, just for the wheels and front bumper. Love it. That's what sold it to me really. Love the early front end & custom grill & splitter.
Daihatsu hijet kei truck brachunky
@brachunky
Club Retro Rides Member 72
Thanks for the inspiration! I have this but yet to start on the wee thing! With availability issues for RHD headlights, pray tell about that cool grill/light cluster set up. That ain't my garden btw lol!!
Last Edit: Mar 6, 2023 23:01:42 GMT by brachunky
Nothing to report except it's finally at home. Plan on removing the bed this weekend.
I put the jet up on ramps & stands so I could get a good luck underneath, then decided to pull the bed for easier viewing. I've decided I'm going to pull out all the brake & Fuel lines & remake them as it's mess. Removed the fuel lines & Fuel tank already & the rear axle is loose & ready to remove. Tank looks a bit crusty so I'll clean that up & inspect it soon. Constructive day & more to come.
Last Edit: Apr 8, 2023 19:44:33 GMT by ianlea73
Somehow I would be tempted to make the cab removable too for a proper overhauling of the chassis. Or for future engine works.
Apr 10, 2023 17:08:33 GMT
Somehow I would be tempted to make the cab removable too for a proper overhauling of the chassis. Or for future engine works. Under the seats are 2 big access panels, everything on the engine can be accessed on top really easily.
v8ian
Apr 10, 2023 17:32:24 GMT
I do rather like this, A good few years ago my mate had a Acty van with a mid mounted Bandit? engine, used to run 14s all day long, makes me think about getting something small for the wifey Bookmarked BTW
May 31, 2023 21:56:25 GMT
I've been debating how I was going to tackle the cab & if I wanted the hassle. At the start of June I bought a pair of doors as mine are a but crusty in places. While buying the guy told me about a hijet pick up local so I asked him to sort a few pics. Fast forward until today & I finally got the chance to go & look at it. Cab is completely rust free & all the mechanicals look great. Low mileage & only 2 previous owners. A deal was done & I'm hoping to have it home next week. I'm going to tackle this a bit different to my normal strip it bare & start fresh, the plan is to sort the engine with a service, strip & rebuild brakes, check bushes, ball joints etc & mot it. Then I'll add my flipped rear axle, coilovers & wheels.
Saw these pics ianlea73 and was not sure if I should post them in your thread as further inspiration or not. If you want me to delete the entry, let me know. I do like a truck.
Saw these pics ianlea73 and was not sure if I should post them in your thread as further inspiration or not. If you want me to delete the entry, let me know. I do like a truck. Saw these pics ianlea73 and was not sure if I should post them in your thread as further inspiration or not. If you want me to delete the entry, let me know. I do like a truck. No they definitely need to stay. Wow that wide body looks amazing. I follow this guy on insta & saw his truck at jdm combe yesterday. 1200cc motorbike monster.
Jul 16, 2023 21:39:41 GMT
The jet never ran when I bought it so this weekend I had a chance to check ignition, relays, coilpacks etc. I have a wiring short or earth somewhere as even with the key out the ignition I have the hazard light & battery light constantly lit up. I removed the coilpacks to check spark & had nothing so next was the ignition module on the rocker cover. It basically fell apart when I unbolted it from the rocker so I went on fb to source a replacement to see if it will sort my issue. Also did a compression test 190-175 on all 4 cylinders so happy with that. New part is ordered so will see if it fires this weekend.
Jul 30, 2023 13:28:55 GMT
While I was waiting for the ignition module to show up I decided to pull the fuel tank & check through the fuel system & I'm glad I did. The petrol smelt like, like, like um stale petrol. The metal return line was corroded & the fuel filter was semi blocked & when I blew it out there was loads of crud. So I've ordered a slightly bigger straight pipe filter, an alloy housing, fuel pump, new 8mm cotton braided fuel line & stainless clips. That gave me time to remove the tank. Stripped, cleaned, jenolite red oxide & hammerite black paint. I've stripped & cleaned the sender & fuel pump housing & replaced the corroded plugs with waterproof ones. Here's where I am at the moment.
Aug 17, 2023 18:22:33 GMT
I've been doing loads too both trucks but nothing to picture. They've been getting on my nerves lately so decided to make a frivolous purchase. Genuine nardi mx5 steering wheel with great lacquer peel & a bit tatty, perfect for this truck. Really like it & it's motivated me again to crack on
The wide body truck belongs to the Drift Games guys in Ireland. They have quite a big YouTube channel.
