Feb 28, 2023 21:15:38 GMT
I'm looking for a rust convertor solution to apply to the underside of my car which ive took back to bare metal with a wire wheel, I've tried using bilt hamber hydrate 80 in the past but end up having paint adhesion problems when I coat over it, so what is the best rust convertor product available ?
Also, I'm in the UK.
jmsheahan
Club RR Member Number: 121
You'll open a can of worms with that question but here's my 10 pence if it's any help. I'm in the same boat as you with bare metalling a car underside. Blasting is obviously the best choice however not practical for us mere mortals working out of our garage/driveways. So, depending on how heavily rusted the surface is and assuming it's still solid/savable, citric acid solution (i.e Deox Gel) is pretty good at getting the rust out of pitted metal. It is however a very slow process requiring multiple applications. I find it's not as effective as the powdered version however dunking an entire car in it may be slightly problematic . It is however the best practice to 'remove' rather than 'convert' rust. I've also found the diluted Phosphoric acid-based solution such as Kleen-B from Rustbusters quite effective at cleaning out/removing rust from pitted metal. Alternatively to that, you're into the convertor/coating methods such as Hydrate 80 you mention, and the likes of Jenolite FE-123 etc. I use Hydrate 80 but I'm on the fence about how effective it is. Once you've removed/converted as much as possible, a good 2-part coating such as an epoxy mastic should seal the area. As I say, you'll have a multitude of answers but that's my take on it at least. Remove rather than convert if you can - hope that helps.
Last Edit: Mar 1, 2023 12:53:33 GMT by jmsheahan
I really rate Hydrate 80 and would suggest contacting their service department for any further tips/advice they could offer with your problem. You could go in circles trying to find the perfect product!
ive heard about 'Rust Kutter' but its from over the pond. Ive seen it compared to other rust treatments and it seems to be the best rust killer/ cleaner before using your paint system.
ClassicResto.co.uk - Restoration and maintenance of classic cars - Wolverhampton.
2002 Mercedes E320CDI Estate 1998 Mercedes C240 Sport 1995 Mercedes SL500 1993 Mercedes 500 SEL 1993 Mercedes 500SL - Sold October 2022 1989 Mercedes 300 CE 1985 Mercedes 500 SEC 1985 Porsche 911 Carrera - Sold March 2022 1983 Porshe 944 1978 BMW 1602 1973 Mercedes 350SL
I use 12% phosphoric acid and patience. Cheap as chips.
I have tried hydrate 80 but I'm not convinced, used it on a rust patch and it was rusty again within a month, I then treated it with cortanin F which was still fine after another 4 months when I got round painting it, I use Cortanin F now.
Are you applying it to rust or to cleaned steel? I've had mixed results with Hydrate when I've gone off the still-rusty bits and onto clean or nearly-clean steel, I assume because there's nothing for it to react with.
If you've got it back to being clean and shiny a good zinc primer will do better - BH do Electrox which is good but very pricey for the coverage.
slater
Club RR Member Number: 78
Don't waste money on 'products' they are all just phosphoric acid in various forms. Go straight to the active ingredient.
probably right there , but i have started using this fertan stuff. it works only on bare metal it seems or falls off, it converts the rust and leaves a zinc layer. it seems magic stuff. the parts not black i hadnt quite got all the paint off.
bricol
that bare metal you wire-wheeled?
If it was rusty before, and is now shiny, go back and drag he edge of screwdriver across it and inspect the sides of the scratch you left?
It'll probably be orange . .. rust . . .
I paid a mobile blasting company to blast the underside of mine - took him longer to set up and pack away than to do it - and I did have to do a fair bit of sweeping . . . but for the clean surface that was perfectly keyed for protective coatings, it would have been cheap at twice the price.
I get the good idea of just using phosphoric acid solutions but are there any good ways of using it on underneath surfaces where it would drop off or are there any suggestions of what you could add to it to maybe make it slightly more effective?
(I have in the past mixed it with oil and put it into my sills but being inside obviously havent seen the results of it)
jgtr
You can get it in a gel form (Bilt Hamber Deox gel) which you can cover with clingfilm
I have heard of people mixing acids into a thicker solution by adding wallpaper paste into it.
Yeah cheers think ive heard of that too on recollection, come to think of it too the previous gels ive used looked pretty similar, would be fairly easy to create a concoction, with phosphoric acid tho would it dissolve the metal too if left on and not washed off or could you just use weaker solutions?
slater
Mar 13, 2023 13:39:37 GMT
Phosphoric acid wont dissolve good steel. It can only dissolve the oxide. (ie. rust)
My only thought with wallpaper paste is what a gloopy mess it will leave behind afterwards but I guess you can use it then clean the curse word off with more phosphoric. Avoid washing off with water if you can.
