v8ian
I have, what I assume is a noisy lifter, certainly a variable tap, TBH I think the lifter has now collapsed or stuck down, The engine has what I think are SBD cams, 196 springs to mind? I know I can pull the lifters and dismantle them, clean out thoroughly, and re-install, do one at a time, and re oil, and refit back in original holes, then hope I have sorted it, down the pub yesterday my mate suggested I buy new lifters and use those, plenty of Zinc based oil and cam lube, off we go, I have my thoughts about this question, but I'm asking for opinions,
Vauxhall 2.0l XE Noisy liftersstealthstylz
@stealthstylz
Club Retro Rides Member 174
You can just fit new ones without changing anything else. They're not like pushrod V8 stuff where they can throw a hissy fit if they're mismatched to the cam.
You've got to remove the cams to get the lifters out, so doing one at a time is idiotic. Remove all 16 to clean them in one go. If you gently squeeze them in a vice first, you'll probably be able to determine which ones don't feel the same.
They come apart by banging them upside down against a block of wood. Clean them in solvent, blow the holes clear, and I reassemble them in ATF so they pump up quickly.
I just rebuilt an XE head a couple of weeks ago - they always tap in XE's for some reason as well, I've never had one that didn't have a few tappers. You can depress them by pressing them down with the rocker cover off and the cam lobe pointing away. I don't think cleaning will do any good tbh, I tried that years ago and I think it was still the same, it's a characteristic of the engine it seems, no harm in trying though.
