merryck
Club RR Member Number: 9
Tot rod wheelsmerryck
@merryck
Club Retro Rides Member 9
Sept 6, 2022 21:44:34 GMT
Anyone got any ideas where to look for something that's not going to cost a fortune, but is going to look reasonably decent?
Ideally I'd like to find a tyre tread that looks like it would've been used on a car, probably 10 inch wheels. All I'm finding are sack barrow wheels, and they really don't have the right look!
Sept 6, 2022 22:10:56 GMT
Anyone got any ideas where to look for something that's not going to cost a fortune, but is going to look reasonably decent? Ideally I'd like to find a tyre tread that looks like it would've been used on a car, probably 10 inch wheels. All I'm finding are sack barrow wheels, and they really don't have the right look! Go-kart wheels with wet weather tyres. Cheap if you look around and ask about. I got two sets free, (traded favours) and gave one set to a mate.
Sept 7, 2022 10:43:38 GMT
My mums old electric mobility scooter had quite a cool looking set of alloys, and I've seen similar ones at the tip recently presumably with dead batteries so you could probably pick a whole scooter up quite cheap
Last Edit: Sept 7, 2022 12:19:16 GMT by Rich: That really wasn’t ok, was it.
merryck
@merryck
I've found some wet weather go kart wheels nearby for £40. I'll go pick them up Friday. I'm not sure they're really what I'm after, but they'll definitely do for now! I've found myself looking at casting my own alloy wheels. It's entirely unfeasible, but would be a lot of fun! I saw Vespa split rims, which you can get quite cheap, but they're 10", so with a tyre they'd be far too big for the body I've got. I couldn't find any other type of scooter wheels that were split and smaller. If I can find something then all I need to do is cut a thick piece of aluminium/steel and bolt them together.
Sept 8, 2022 10:04:23 GMT
what are you putting them on ? as in what type / style of tot rod here's a couple I had for my grandson
merryck
@merryck
Sept 8, 2022 12:52:42 GMT
I can't seem to find the original listing, but it looks to be the same body as this one; www.ebay.co.uk/itm/303826804868?hash=item46bd7d2084:g:OBAAAOSwpkpf6RovThe go kart wheels look great on the red single seater you built, hopefully they'll go well with the body I've got. I think I had a thread somewhere, just after he was born! Once I get going with it properly I'll start updating it again.
Sept 8, 2022 15:33:28 GMT
I can't seem to find the original listing, but it looks to be the same body as this one; www.ebay.co.uk/itm/303826804868?hash=item46bd7d2084:g:OBAAAOSwpkpf6RovThe go kart wheels look great on the red single seater you built, hopefully they'll go well with the body I've got. I think I had a thread somewhere, just after he was born! Once I get going with it properly I'll start updating it again. the go kart wheels off my red single seater might look a wee bit out of place on such as short body but give them a try and see how it looks
merryck
@merryck
Sept 8, 2022 16:01:54 GMT
That was my initial concern over go kart wheels. Far too wide, but I've found some almost as cheap as two sets of the sack barrow wheels that the yellow one has on it would be, and they don't look too good either, so if I go with the go kart wheels, at least I'll have them for the next iteration of it.
Plus, wider is always better, and while I might just be pushing him round a car show you never know when you're going to want the extra grip. You never can be too safe.
please post a pic up with the go kart wheels against the body you could stretch the body a bit to get the right look
merryck
@merryck
Sept 9, 2022 19:01:11 GMT
Yeah, the go kart wheels are dead on, top work grizz . I had looked previously, but all I could find were ridiculously wide ones. I looked again after you suggested them and these were the first result. I've mocked them up very roughly where they're going to sit. It might end up sitting a little higher than this, but I'm hoping that it won't be too far off. Just doing all the drawings tonight for the bits I need laser cut. I'll be making a solid axle over the weekend, and the beginnings of a chassis. Deadline is the 25th for the Oh So Retro show in Margate. Plenty of time!!
Sept 9, 2022 20:50:36 GMT
Yeah, the go kart wheels are dead on, top work grizz . I had looked previously, but all I could find were ridiculously wide ones. I looked again after you suggested them and these were the first result. I've mocked them up very roughly where they're going to sit. It might end up sitting a little higher than this, but I'm hoping that it won't be too far off. Just doing all the drawings tonight for the bits I need laser cut. I'll be making a solid axle over the weekend, and the beginnings of a chassis. Deadline is the 25th for the Oh So Retro show in Margate. Plenty of time!! excellent first mock up great wheels looking forward to see this one done
merryck
@merryck
Sept 10, 2022 17:04:48 GMT
Looks like the inner diameter of the bearings on the front wheels is 17mm - I had planned to make the stub axles out of threaded rod, but it'll either be 1mm too big or small. Are there any imperial sizes that might do? I've not got easy access to a lathe, otherwise it'd be rather simple!
merryck
@merryck
Sept 11, 2022 21:17:43 GMT
Bit of a thread hijack sorry, I've just put a petrol gokart i have for sale in the whats it worth thread as i didnt know where else to list it but feel someone interested might not look there buy might be reading your thread merryck hope its ok.
