ems1
Club RR Member Number: 5
Manta clutchems1
@ems1
Club Retro Rides Member 5
Jul 30, 2022 16:30:21 GMT
I removed the clutch from the Manta today and noticed the springs have been rubbing against the ARP bolts. It's a C20XE with flat flywheel and Manta 1.8 gearbox. On one spring it's worn through a third of the wire's diameter, is it safe to re-fit or do I need a new clutch? Has anyone else had similar problems? Thank you.
Last Edit: Jul 30, 2022 18:01:24 GMT by ems1
1985 Manta GT/E 16v 2001 VW T4 Caravelle
Jul 30, 2022 19:39:10 GMT
is the friction plate in the right way around? Is it not a calibra?
Last Edit: Jul 30, 2022 20:29:20 GMT by bmw2101
ems1
Manta clutchems1
@ems1
Just checked, the clutch centre is offset so the friction plate can only fit one way.
colnerov
Jul 31, 2022 12:28:35 GMT
Hi, Yes traditionally the 'flat' side goes to the flywheel and the spring pack side goes into the clutch cover. Is the friction plate more worn one side than the other?
Colin
Last Edit: Jul 31, 2022 12:30:48 GMT by colnerov
Jul 31, 2022 12:34:16 GMT
Its been a long time but I'm pretty sure you have to mix and match the kits, wouldnt mind betting you have a complete FWD kit
