voodoo57
That's not 2 metres! come a little...Closer!
Club RR Member Number: 137
16v mk6 zetec pipe required voodoo57
@voodoo57
Club Retro Rides Member 137
Hi Folks, i think i have a nasty oil leak from the breather pipe on the w reg ford escort 16v 1600cc ? it's the pipe that goes from the front corner of the engine goes under the air filter piping and coil pack round the to the rear, it's pouring over the gearbox, first thought it was the corner of the rocker cover, but that remains dry, anyone have a car part number or a replacement part? T.I.A
May 10, 2022 13:34:17 GMT
I can look it up as i have Ford Micro cat System and can get the part Number and Finis . Just need the reg .
Last Edit: May 10, 2022 13:34:53 GMT by cpj105e
voodoo57
@voodoo57
May 10, 2022 18:49:12 GMT
W468UEV Thank you
May 10, 2022 19:41:06 GMT
7 is Finis 1053252 part number 958F6758EA 8 is Finis 6599916 part number 928F6N664JB 9 is Finis 1050948 part number 958F6N664EA Hope this helps. if you would like a copy of your Escorts factory build sheet i can message you that
voodoo57
@voodoo57
May 10, 2022 20:41:41 GMT
That's perfect, thank you very much!!!!
voodoo57
@voodoo57
May 14, 2022 17:59:31 GMT
All sorted!
