Battenberg
Time for Cake....
Apr 27, 2022 15:25:16 GMT
Hello
My Rev counter in the Wolsely reads way over, does anyone have recommendations of companies that can calibrate them?
Alisdair
Current Fleet: 1968 Wolseley 1000 2022 BMW 430xd MHT Coupe 2007 L200 Animal - Dog walking transport 1998 318is Coupe 2007 Mini Cooper Supercharged 1989 BMW 530 - in storage
Apr 27, 2022 16:50:02 GMT
Hi, Electric or Mechanical?
Colin
Battenberg
Time for Cake....
Apr 27, 2022 17:46:58 GMT
Hi, Electric or Mechanical? Colin Electrical….
melle
South West
It'll come out in the wash.
Apr 28, 2022 15:49:37 GMT
Is it a generic one? For a different number of cylinders than your engine perhaps?
Battenberg
Time for Cake....
Apr 28, 2022 18:35:10 GMT
It’s a Smiths 80mm Gauge that on idle is reading 2000 ish RPM and spends most of its time around 7K!
I suspect it was originally from a V8 hence the recalibration needed.
Apr 28, 2022 20:48:26 GMT
If you are using a rev counter designed for a different number of cylinders this can solve the issue www.ebay.co.uk/itm/284440826701 its a rev counter rpm converter. You wire it into the signal wire from coil to rev counter and it adapts the signal from whatever the engine is to match what the the rev counter is expecting.
Its made by a company that i have been buying electric steering column controllers off for years and they make very good stuff.
Battenberg
Time for Cake....
Apr 28, 2022 22:10:47 GMT
If you are using a rev counter designed for a different number of cylinders this can solve the issue www.ebay.co.uk/itm/284440826701 its a rev counter rpm converter. You wire it into the signal wire from coil to rev counter and it adapts the signal from whatever the engine is to match what the the rev counter is expecting. Its made by a company that i have been buying electric steering column controllers off for years and they make very good stuff. Thanks Mantasport, I have hit the buy it now button.
