ferny
Club RR Member Number: 13
Citroen Dispatch panhard rodferny
@ferny
Club Retro Rides Member 13
Apr 11, 2022 21:26:58 GMT
Hi all, real long shot here and the photos have the main details. My friend has a 2002 Dispatch with a slightly rusty part. She's been told by her garage it's a panhard rod and apparently there are two types - typically the one she needs no-one can find. I've tried and can't even find a diagram listing it and it looks nothing like my 2005 Peugeot Expert. So, can anyone help? Looking around, what are the issue with just swapping the entire rear with the other type? I've not seen the part as she lives 100's miles away, but if it's got enough meat on it I'd be tempted to sleeve and weld.
Last Edit: Apr 11, 2022 21:27:24 GMT by ferny
ci.catcar.info/peugeot/img/pr/30/00092830.jpgAnything on there look vaguely correct? I note the van is registered as an 815kg variant. Sounds like you have an Expert 3, 05 was around changeover, expert 2 looked similar but had a lot of differences.
Last Edit: Apr 12, 2022 2:34:03 GMT by welshpug
ferny
@ferny
ci.catcar.info/peugeot/img/pr/30/00092830.jpgAnything on there look vaguely correct? I note the van is registered as an 815kg variant. Sounds like you have an Expert 3, 05 was around changeover, expert 2 looked similar but had a lot of differences. Cheers for the help. Mine is deffo a mk2 and has what's in your image. Part #2 is what I think the item is meant to be, but the ends are turned up and bigger.
madmog
Club RR Member Number: 46
Citroen Dispatch panhard rodmadmog
@madmog
Club Retro Rides Member 46
Can the one pictured not be repaired by welding? I don' mean a bodge but cutting the hole back to good metal and welding in the correct thickness of fresh metal?
ferny
@ferny
Can the one pictured not be repaired by welding? I don' mean a bodge but cutting the hole back to good metal and welding in the correct thickness of fresh metal? That would be my plan by now. I've not seen it in person as she's 200 mile's away and is getting a garage to do the work which is why a bolt on replacement is preferable. I might be able to see it at some pount this weekend.
