I have just purchased a bike via policy auctions, that does not have the V5C.
For me to get a new V5c I need the VIN but can not find it anywhere on the bike (have stripped it down & checked the manual). DVLA will not give me it as I don't have the V5c. Yamaha won't answer me, so I am stuck going round in circles.
Can anyone tell me how I can get the VIN number so I cn get a new V5c?
Last Edit: Feb 8, 2022 12:33:53 GMT by kerryg
hopeso
Motorbikes have the frame number usually stamped into the headstock area and the engine should have a number stamped onto the crankcase. If the frame number has been removed then you will be in bother unfortunately.
Feb 10, 2022 23:09:09 GMT
Do you mean Police auctions? If so they are break/ dispose or off road use only usually due to the fact they are usual outstanding stolen or proceeds of crime that can't be positively identified. This should have been clear at the auction?
Only thing you can do legally is buy another frame aand get it reregistered as a rebuilt vehicle using the bits from what you've bought. Expect a Q plate though.
Last Edit: Feb 10, 2022 23:10:02 GMT by dodgerover
joda
Feb 14, 2022 15:20:43 GMT
Feb 14, 2022 15:45:42 GMT
assuming you have the reg any of those hpi check or whatever services will give you the VIN won't they? i did it the other way round as i only had a VIN and got the reg from isitnicked dot com
Feb 14, 2022 16:29:29 GMT
What bike is it?
Feb 15, 2022 12:41:19 GMT
i may be able to look it from the reg
PM me if your not sorted already
pow
Mar 11, 2022 15:08:45 GMT
