Jan 24, 2022 15:55:24 GMT
How can one new one not fit despite being able to swap them. Binds after a turn. Old one goes in and out easy too.
I swapped them around and both new ones fit the drivers side smoothly.
But both new ones refused to go on passenger side.
Yet old item I removed goes on and off easily.
Helpโฆ.!!
Jan 24, 2022 16:36:46 GMT
Different thread pitch?
Jan 24, 2022 16:52:28 GMT
I would run a tap and die down each thread before checking again.๐
Jan 24, 2022 16:59:08 GMT
Does the old nearside one fit on the driver's side? If not I'd think thread pitch as suggested by duggers
mk2cossie
Club RR Member Number: 77
Tie rod end binding. Why? mk2cossie
@mk2cossie
Club Retro Rides Member 77
Jan 24, 2022 17:16:34 GMT
Is it possible one side has a metric thread, the other is imperial?
Jan 24, 2022 17:41:10 GMT
Old Drivers side fits both sides.
Old passenger side fits both sides.
New items both only fit drivers side.
Confused.
mk2cossie
@mk2cossie
Jan 24, 2022 18:32:08 GMT
Old Drivers side fits both sides. Old passenger side fits both sides. New items both only fit drivers side. Confused. I'd be inclined to run a die along the steering arm section of both sides, and possibly run a tap down both new track rod ends to confirm/remedy any thread issues on either side. Would also show up if one is UNF instead of metric thread that way
Jan 24, 2022 18:32:57 GMT
Can you see anything on the threads that may be causing the binding? Could be microscopic damage. Still doesn't explain why the old ones fit though?
Jan 24, 2022 18:50:23 GMT
Old Drivers side fits both sides. Old passenger side fits both sides. New items both only fit drivers side. Confused. I'd be inclined to run a die along the steering arm section of both sides, and possibly run a tap down both new track rod ends to confirm/remedy any thread issues on either side. Would also show up if one is UNF instead of metric thread that way Spot on. And then it was sorted. Run through and run over with appropriate Tap and Dies to clean it all up, Borrowed from neighbour Stuart who has bought Sallyโs Opel Corsa. Old and new. Weird sh!t Thanks for the responses and advice.
Jan 24, 2022 19:08:41 GMT
At least you didn't have to use a drill
Jan 24, 2022 19:13:27 GMT
At least you didn't have to use a drill Or a BFH๐๐
