Hello guys! I need your advice to step by step with this magical rust removing concentrate. I used it for 24 hours in mixed bath(Deox-C with water) and how to prepare next metal. Is it need for wipe it dry afterwards or just wash with clean water and immediately later apply some primer? What is best solution for primer and how to/ best way to that at home? Bilt Hamber Electrox?
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
I just wash off and scrub with a clean brush and use electrox. You could always wipe with panel wipe too.
I just wash off and scrub with a clean brush and use electrox. You could always wipe with panel wipe too. Thanks mate. Ok, I will do that way. But just one problem I haven't got electrox yet, maybe I will try some other primer.
vanpeebles
Dec 10, 2021 10:33:49 GMT
I also use etchweld too
Dec 10, 2021 22:58:06 GMT
Wash it in cold clean water, dry with a clean towel or paper or blow with compressed air to blow most off. Definitely don't dry using heat, it'll flash rust. Leave it to dry 100%, then apply whatever primer you like to it then paint. Theres no rust, and a good surface for primer to grip to, whatever your chosen primer is will work well.
Electrox is good though.
Dec 11, 2021 21:43:02 GMT
If it will fit I'm a domestic oven, 1/2 hour at 120 works well to dry it out before paint, just done so with a pair of mini wheels.
