Afternoon all, just wondering if we have some people on here in the know about R1 carbs?
I've had these sat years after a failed turbo application now wanting to use them in N/A again
Apart from the obvious cut trumpet bits as I connected to a plenum I'm struggling to understand what I do / where the three air pipes go in N/a (the black silicone ones two kid and one on the right) and there's two brass take offs one on the left and one under I'm guessing fuel, both or just the lower one?
Then it looks like a little piece of metal has been inserted into a brass fitting with some sealer on it in each one, again must have been for turbo app, so assuming return to normal but what are they?!
It's been many years since I've even looked at these so just trying to get back to grips with them! Many thanks in advance
