For ages I have wanted a small tool bench with decent wheels I could wheel across our rocky yard for working on cars/trucks/tractors outside. Its always been on the back of my mind to build but I never got around to it. Earlier this year a retired friend gave us a load of old tools and workshop stuff including his old tool cabinet. It was pretty beat up and had tiny little wheels but the drawers work really well. So now I had a base to start with. NZ made. Guessing its 80's going by the font on the sticker.
NZ made wheels too..
I started with the build by hacking it apart...
Luckily the drawers bit I wanted was self contained..
I had kept a section of old stainless steel bench top left over from some project I cant remember. It was missing one end but I had a plan and it was always going to be used for my ideal toolbox design..
I cleaned it all up, removed all the tar like glue that was on the underside and cut, bent and welded up the other end to match. I also welded up a drain hole it had..
I ripped down some eucalypt timber and cut it into an angle profile then used it to edge the stainless, now glued onto a sheet of ply.
So with the top sorted I started on a frame. I needed some wheels and I had just the ticket. I have had these two wheels stashed away from when I did my apprenticeship back in the mid 90s. I was building a scooter that used a weedeater motor but never finished it. I had thrown away the rest but kept these new wheels. I still had the bearings they came with too.
I machined the ends of some thick pipe to suit and made an axle...
I bought some 100mm castor wheels with locks for the back from Mitre 10.
Now a frame to mount them on. I rummaged through the steel rack and found suitable stuff to use...
The drawers sit in place like such...
I removed the handles and Hannah cleaned the drawers up so I could lob some paint at them..
Now I could start cladding it in plywood, using stuff left over from the mezzanine build.
I had a pair of 500mm drawer runners from Bunnings left over from the kitchen build. Handy for a large drawer below the others..
Folded up a bit of sheet steel for the front...
Made some stainless handles to match the others...
And this is where I am up to so far...
My next thing to sort out is the slide up section that all my spanners will go on. Then some handles, and finish the top cover that will be hinged so it can open out doubling the top area and exposing the stainless tray.
We've already had some fun today going to Bunnings and Mitre10 selecting a few tools to add, the idea being I can almost clear the work bench area fully of car related tools.
Itching to get back into finishing this now :-)
