93fxdl
Enter your message here...
Oct 14, 2021 21:51:38 GMT
Pulling apart an engine that has been sat in a garage for over 30 years, at some time prior to that one of the plugs had a repair insert fitted, which is now seized onto the plug. Plug now broken, so drilling it out of the insert is the next step, but would be handy to know what the insert is if it all goes even more pear shaped Ps the straight lines are vice grip Mark's, another reason sourcing a replacement would be preferable Ttfn Glenn
No idea where it came from but have you tried heating it up to get it off?
Oct 16, 2021 14:55:26 GMT
Something about that screams ' plumbing fitting' to me 🤔
Oct 16, 2021 18:52:01 GMT
Can you make out any of the lettering?
Oct 16, 2021 19:24:42 GMT
Can you make out any of the lettering? Seems to say "made in" so I'm going to guess the next work is England, or Britain? Oh, I zoomed in, I think it says made in Japan.
Last Edit: Oct 16, 2021 19:25:45 GMT by VW
93fxdl
Oct 17, 2021 15:47:34 GMT
Further investigation reveals the plain section is part of the broken plug, the insert is just the threaded section. So a coarse tapered thread on the outside with the fine plug thread inside Thanks everyone but the search continues Ttfn Glenn
Oct 17, 2021 16:05:11 GMT
looks like a timesert or similar, though I thought they tended to have the same thread pitch externally so that the internal threads push the material out to bite into the parent material with the square/oval fitting tool.
what is the plug thread and outer thread of the insert?
93fxdl
The inner is a 12mm plug thread, the outer looks almost like 1/2 bsp or similar whitworth/unc Ttfn Glenn
Oct 21, 2021 10:03:58 GMT
I used to sell this in the 90s as a spark plug repair kit, might still have one?
It will come in handy even if you never use it
93fxdl
Oct 21, 2021 11:10:54 GMT
I used to sell this in the 90s as a spark plug repair kit, might still have one? If you do, that would be awesome or failing that, if you could remember the brand would be excellent. Closest I seem to be able to find is a timesert oversized Ttfn Glenn
Oct 26, 2021 14:48:35 GMT
Sorry Cant find any, I am sure Ebay would have them it was a generic Chinese one sold by most motor factors at the time
93fxdl
Oct 26, 2021 19:58:05 GMT
Sorry Cant find any, I am sure Ebay would have them it was a generic Chinese one sold by most motor factors at the time Ok thanks, currently misplaced this one so could be fun times if I cannot find it Ttfn Glenn
