Sept 21, 2021 8:05:43 GMT
Got the Airbag warning light on the dashboard and scanning the codes indicate it's the passenger seat occupancy sensor, I've seen loads of write ups and You Tube videos about the little Bypass modules and have a technical question I can't find an answer to : Will using one mean that the airbags etc still function correctly in the (hopefully never !!) event of an accident ??
pow
Sept 21, 2021 10:21:04 GMT
From memory you can get ones that fool the seat into thinking its permanently occupied or permanently unoccupied - so airbag on or airbag off. As I am without children I'd rather it went off when noone was sat in the seat than it not go off if an adult was in the seat.
Rich
Club RR Member Number: 160
BMW Seat Occupancy Bypass ??Rich
@foxmcintyre
Club Retro Rides Member 160
Sept 21, 2021 12:22:56 GMT
The bypass module just tells the SRS module that the seat is occupied and the belt is fastened so in the event of (relevant) accident the bag WILL be triggered to deploy.
Last Edit: Sept 21, 2021 19:31:40 GMT by Rich
Sept 21, 2021 12:48:16 GMT
Pow & Rich, Thank you both very much, Set my mind at rest, Nigel
