mylittletony
Club RR Member Number: 84
Someone to tune a carbmylittletony
@mylittletony
Club Retro Rides Member 84
Hi all
Looking for someone local to me (RH18) to tune, or help me tune, my holley carb. Closer the better, it drives ok but it's setup conservatively rich.
Many thanks!
Paul Y
Tony, Too far away to help directly but there is a great book called, how to power tune your Holley that helped me get my 830dp pretty much on the money. A cheap vacuum gauge really helps as well plus the obvious jets and power valves. I have a copy here you can borrow if you get stuck. P.
I had my Jag set up on the rolling road at CCK Historic who are about 10 miles form you www.cckhistoric.com/contact/I'm sure they could sort it for you.
Old Fords never die they just go sideways
