It has a towbar.
Hi I got a fresh ticket on this today and it's now for sale as surplus to requirements. It's a 2.0 non turbo on 201,000 miles (insert cliche about just run in) and is an honest old bus. It failed initially on lower ball joints but they were changed today and it also has four new tyres.
It does use coolant but not investigated this, just kept topping it up.
While up on the ramps took photos of the only rust I could find in the front wheel arches. Obviously not even an advisory but thought I would mention it.
Interior is generally OK but big hole in carpet drivers side. Also heater valve is sticky/broken
Alpine USB and CD head unit.
Comes complete with a bottle of T-cut and HBOL.
T-cut sorely needed on the roof!
Anyway for this fine machine I am looking for £940.
£940 for a 940.
Located in Tamworth and happy to put it up on the ramps for anyone who wants to see underneath before purchasing.
Repair as soon as possible (minor defects):
Nearside Steering rack gaiter damaged or deteriorated, but preventing the ingress of dirt (2.1.3 (g) (i))
Offside Steering rack gaiter damaged or deteriorated, but preventing the ingress of dirt (2.1.3 (g) (i))
Monitor and repair if necessary (advisories):
Front Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Power steering component has slight seepage from a component rack (2.1.5 (a))
Nearside Front Anti-roll bar pin or bush worn but not resulting in excessive movement D bush (5.3.4 (a) (i))
Offside Front Anti-roll bar pin or bush worn but not resulting in excessive movement D Bush (5.3.4 (a) (i))
Nearside Front Anti-roll bar linkage pin or bush worn but not resulting in excessive movement bush worn (5.3.4 (a) (i))
Offside Front Anti-roll bar linkage pin or bush worn but not resulting in excessive movement bush worn (5.3.4 (a) (i))
Nothing serious on the advisories, mainly bushes.
