Kron
Mar 21, 2021 22:09:00 GMT
Ok, u have what I assume is a sealed lead acid battery that's approaching 10 years old.
The recent cold and lack of use has seen it need a couple of charges to put some magic smoke back in the box.
Question is, is it possible to rejuvenate the life of the battery by topping up, or is it not worth the hassle these days?
Is there any way to tell if a top up is required ?
Mar 21, 2021 22:29:21 GMT
Quite often 'sealed batteries are not that once you peel labels off. Ultimately depending what type of battery you have they can be had delivered with 4/5 year warranty for not much. I use a seller by the name of Tayna on the bay of evil do everything from budget to premium all at good prices.
Mar 21, 2021 22:29:35 GMT
If it's 10 years old, it's done well. That's 4 - 5 years longer than they usually last. Because I'm cheap, I've have been known to attempt just what you suggest on a couple of occasions. It is usually possible to get the cell caps off (though it'll never look the same again), and you may well find some of the cell are wanting topping up. However, even if you do this, your battery will most likely still be goosed.
I won't bother again. I'm lazy as well as cheap......
Nick
Stiff
'kin 'ell
Mar 21, 2021 22:53:14 GMT
As above. Mine went the other day on an '08 Sprinter. It was the original Merc battery from factory so after 13 years, it had done well. £70 for a decent new one (there was a cheaper one for £50) so it's really not worth messing around with the old ones. The van even starts better in a morning now. Bonus.
Mar 22, 2021 10:09:32 GMT
Like has been said time for a change. Last thing you want is for it to give up on you whenyou are in the middle of nowhere.
jamesd1972
Club RR Member Number: 40
Mar 22, 2021 10:54:03 GMT
Don't forget that the old one will be worth a tenner or so from the scrappie to help soften the blow of a new one.
James
Mar 27, 2021 17:30:36 GMT
I second Tanya, I ordered straight from there website, lots of choices from cheap to more expensive brands, they provide an excellent customer service, when I ordered in the afternoon my battery was delivered to me 24 hours later at very good prices in my opinion.
All the best.
Cheers.
Daily 2014 VW Passat & 1995 Vauxhall Cavalier CDX Summer months 1986 Vauxhall Cavalier L Project 1984 Vauxhall Cavalier GL
Kron
Mar 28, 2021 17:20:00 GMT
Thanks guys, reckon that confirms my thoughts that it's probably not worth faffing about with; just get a new one and be done.
Still the old optimate seems to be keeping it alive for a couple of months at a time lol. Nothing like life on a budget.
Last Edit: Mar 28, 2021 17:21:50 GMT by Kron
