goldnrust
West Midlands
Minimalist
Mar 13, 2021 19:01:10 GMT
As others have said, nice to see another being saved You're doing well if you've avoided the sill rusts that is so common on these. It's always impressive how pink that red Mazda paint can go! haha. Just watch out with the aggressive T-cutting, my mum managed to polish through the paint on her bonnet in the battle to keep it red rather than pink! As you've said you're only going to use this for the summer 6 months, my vote is for a cheap and cheerful vinyl roof with the plastic rear window. If you're only using the car in the summer then the roof should be down most of the time anyway, so its just there to keep the rain out when it's parked. The mohair roofs look/feel a bit fancier, but they do require a bit more careful looking after. If you do look after them right they should outlive a vinyl roof. But again, if you're not subjecting the roof to there worst of the winter weather, it seems less of a big deal to me. The main draw back (to me at least) of the plastic window is that as they age they can go cloudy and obviously there's no heated element so condensation in the winter can be a pain. The glass windows are heavier, but some people prefer that crystal clear view even in the cold damp winter. I refer you to my previous point about the roof being down!
Battenberg
Time for Cake....
Mar 13, 2021 19:34:39 GMT
As others have said, nice to see another being saved You're doing well if you've avoided the sill rusts that is so common on these. It's always impressive how pink that red Mazda paint can go! haha. Just watch out with the aggressive T-cutting, my mum managed to polish through the paint on her bonnet in the battle to keep it red rather than pink! As you've said you're only going to use this for the summer 6 months, my vote is for a cheap and cheerful vinyl roof with the plastic rear window. If you're only using the car in the summer then the roof should be down most of the time anyway, so its just there to keep the rain out when it's parked. The mohair roofs look/feel a bit fancier, but they do require a bit more careful looking after. If you do look after them right they should outlive a vinyl roof. But again, if you're not subjecting the roof to there worst of the winter weather, it seems less of a big deal to me. The main draw back (to me at least) of the plastic window is that as they age they can go cloudy and obviously there's no heated element so condensation in the winter can be a pain. The glass windows are heavier, but some people prefer that crystal clear view even in the cold damp winter. I refer you to my previous point about the roof being down! Thanks for your comments and advice, in your experience is it also advisable to replace the rain rail also? I’d rather order everything at once to save leaving the car in bits.
Current Fleet: 1968 Wolseley 1000 2022 BMW 430xd MHT Coupe 2007 L200 Animal - Dog walking transport 1998 318is Coupe 2007 Mini Cooper Supercharged 1989 BMW 530 - in storage
goldnrust
West Midlands
Minimalist
Mar 13, 2021 19:42:11 GMT
I've had several different Mk1s with the various roof options, but I've not actually replaced a roof so I can't comment on the rain rail, sorry!
Mar 13, 2021 21:21:06 GMT
Looks a great project, I fitted a mk2 frame and hood, gives you a reasonable sized glass rear heated screen.
The rain rails often break when removing the hood I ended up having to repair a couple of small cracks in ours with aluminised tape which has lasted well.
Mar 13, 2021 22:33:57 GMT
Nice project, supricingly rust free. I'd be more worried of rain rail than the roof as it cost's more than cheapest vinyl roof and is usually quite brittle. I'd bin soft top and have only hard top, but thats me. Have you check'd the drains aren't clogged? Are you going to keep it stock?
Last Edit: Mar 13, 2021 22:34:39 GMT by samulis
Battenberg
Time for Cake....
Nice project, supricingly rust free. I'd be more worried of rain rail than the roof as it cost's more than cheapest vinyl roof and is usually quite brittle. I'd bin soft top and have only hard top, but thats me. Have you check'd the drains aren't clogged? Are you going to keep it stock? Hello I will order a rain rail and hood, if the rain rail is ok I can just return what I have but for longevity and best practice I think it makes sense to replace both, not checked drain holes yet, that will be on the list todo when the old roof and frame come off.... currently it is under a waterproof cover and has not leaked. A couple of people have suggested just a hardtop, however it’s not a one man job to remove them so don’t want to add that complication 🤔 It will be staying stock right down to the steel wheels, I have enough quick machinery to hand if required so want to keep it stock for the purists.
e30ben
Great find and progress!
I’ve always found t cut a bit too aggressive and hard work for what it is.
I can recommend turtle wax colour magic for red, does a great job and it doesn’t require a machine polisher.
My bmw was near as pink as your mx5, gave a lovely shine and the red looked deep after.
Battenberg
Time for Cake....
Mar 14, 2021 11:10:33 GMT
Spent an hour this morning with some Maguiers two step a friend of mine told me to try, tried it with the machine polisher first but wasn’t working as expected so broke out the guns and manual labour commenced. The below took roughly an hour and 4-5 applications, great 10 yarder but does require one more application to remove the oxidation. Good news all round and the paint is recoverable albeit not to a showroom or new car standard but will have ‘patina’ ..... Once again not ideal conditions to polish a car but good results...... I still hate cleaning cars though 😈
paul99
Mar 14, 2021 14:07:10 GMT
With paint that discoloured, I'd be tempted to contact any paint restorers to see if they wanted a 'before and after' sample Good find, looks like a sound car under that
Battenberg
Time for Cake....
Mar 20, 2021 17:11:02 GMT
Hello Managed a few hours between other chores today and surprisingly no hangover which allowed me to get on with the mind numbing job at hand,,,,, the paintwork! I ordered some more G3 and a Maguiers Ultimate Compund to crack on with. Machine polish and G3 really did’nt touch it, but 3 Machine Polishes with G3 and a finish off with the Maguiers gave pretty good results, to be honest I think another application of the Maguiers will get it as good as it’s going to be...... I’ll let the pictures do the talking for the few areas I have done so far... I had to go and get one of my other Cars from storage so when I returned it was getting to cold to polish ( thank god!! ) so I took the wheels off and put it on stands, the tyres will be taken off so I can refurb the steel rims to get that job ticked off the list. While their I noticed the back pads have less meat than a cat walk model so I will replace front and rears place change the brake fluid, service and change the cambelt. While in the air I pulled out the hose and cleaned the wheel arches out, one would have used the petrol power washer but next door is expecting child and did not want to add too much stress to the situation, results below... Quite pleased with the above, no frilly arches either, below is a shot of one sill showing how solid they are.. The only sign of grot is on the o/s rear sill end which looks to be water ingress under the stone chip, a prod with the technical tapping tool and its surface rust so I will clean it up and reapply a stone chip along both sills. I have to build some planters tomorrow and do some gardening chores but hope to finish the paint and lube up the hood mechanism ready for hood replacement next month!! Thanks for looking, and as I have had a busy day outdoors I have decided to treat the bin lids to a takeaway tonight to save me cooking, personally I’d like a Chinese but ultimately the decision is with the GF as she is running a half marathon tomorrow in prep for the London Marathon she has a place in!!! Thanks for Reading
Last Edit: Mar 20, 2021 17:14:47 GMT by Battenberg
Mar 20, 2021 17:58:41 GMT
What a transformation already, I'd been really pleased with that. We're after a cheap 4 seater cabrio at the moment,so that the whole family can go out in it, but the more I see these MX5's being saved,the more I'm drawn to them.
Mar 20, 2021 22:33:37 GMT
Can you let me know what order of materials to do the mop & polish? On mine I've used g3 by hand on my mirrors & number plate panel. I want to do my main panels with my mop but unsure what process to do. You are using g3 & 2 meguiars compounds, which way round are you using them?
Last Edit: Mar 20, 2021 22:34:35 GMT by ianlea73
Battenberg
Time for Cake....
Can you let me know what order of materials to do the mop & polish? On mine I've used g3 by hand on my mirrors & number plate panel. I want to do my main panels with my mop but unsure what process to do. You are using g3 & 2 meguiars compounds, which way round are you using them? Hi Ian As the paint is proper buggered I’m using 2-3 applications of G3 with the Mop, this turns it to a hazey red, following this Maguiers ultimate cutting compound applied by hand, again 1-2 applications per panel depending upon finish. The boot received a cost of Autofinesse One Step that I have used on one of the other Cars, once I have reassembled the MX5 with refurbed wheels and new hood this will be used for the final polish. Red is a b1tch to work with as we all know and I suspect yours will me more forgiving.
That's brilliant info mate. I guess I'm going to get on Ebay & order some meguiars.
Battenberg
Time for Cake....
Mar 23, 2021 18:43:22 GMT
Spent an hour tonight with a wool mop head as I wasn’t happy with the cut the foam pad was giving me, certainly worked quicker and the ‘clouding’ nearly gone. I would have taken some photos but diner preparation was needed due to hungry bin lids!
I need another couple of hours to finish the near side and will then revert to a foam pad with G3 all around and then Maguiers cutting compound by hand.
I dropped the rims off to be de-tired ready for a clean and spray, the tyre fitters said they could get them refurbed for £200 which seemed a little excessive for steel rims??? If they were alloys then I would say it was a cheap price for a strip and powder coat but also not seeing any of their work and wanting to do as much hands on as possible was another determining factor.....
Mar 23, 2021 20:33:09 GMT
It's a while since I had some blasted but I would expect you could get them all blasted and zinc sprayed for around £100. The last set of steels I did I de-rusted electrolytically in a dustbin then hand sanded, epoxy primed and top coated, they seem to be holding up well.
1997 Mazda MX5 MK1ballbagbagins
@ballbagbagins
Club Retro Rides Member 164
Mar 23, 2021 20:40:30 GMT
Just had a set of alloys blasted and powder coated for 250 and the finish is excellent. Not sure if the process for steels is different to alloy.
Battenberg
Time for Cake....
Wheel Update I set about the wheels last weekend, firstly a wire brush followed by wire wheel on a drill and then a 800 grit to take out any deep imperfections. I then liberally brushed on a rust killer I found from a decade or so ago then as directed rinsed them off the following Day. I have been working Dubai hours this week which meant a 6 am start meaning a wake up call at 5 am...... why is this important you may ask, well I managed to have a couple of warm afternoons to spray the wheels. Two coats of primer, inners in satin black and outers in a generic silver from amazon, two coats each and then lacquered also. I ordered some Avon tyres from Blackcircles which mail ordered turned out to be 37 quid a corner.... quite reasonable but I had to pay for removal and fitting on top...... Below is the only photos I have of the finished article....... Discs and pads were orders last Saturday, I think it was either euro car parts or GSF had a 60% off sale and the parts came in at £160 so I ordered them from RockAuto in the states for £116 to find out if I went to MX5 Heaven in the UK they would have been £100. Either way money saved but it will pay to shop around more in the future! Hoping to get the wheels on tomorrow and a seat in so it can go to the garage for a cambelt next week then go into my storage so I can take the hood off and replace it while the Porsche is not in their.... all busy busy and as usual my faithful garage will do some of the mechanical stuff as my work takes priority. Thanks for looking and Happy Easter..... I can highly recommend a very chilled Villa Maria Sauvignon Blanc with black bomber cheddar and proper chunky Branston Pickle!
Good job on those wheels, they look very tidy. I hope to get my roof swapped today.
Battenberg
Time for Cake....
So..... bit of a change to today’s plan of removing the roof, a friend has a Skoda Felicia FIA log booked Rally Car he purchased a while back to accompany his collection, plan is to do targa rally and it has been going through several changes to comply with the rules, one of these is it has to be back to one colour with a headliner and numerous other things. Following a reversing incident in the dog walking L200 with a tree piloted by my girlfriend, I purchased a Amazon dent puller that gave pretty good results on repairing the tailgate and a dent in the side tub caused by me sliding into a 30 speed limit sign..... the less we say the better!,, Anyway, pictures below.... The Skoda has been rolled before and sustained damage to the rear and OSF roof skin, the rear I managed to move slightly but it has a lot of WOB on it so resulted to a jemmy bar with a rubber tip which cracked the filler but restored some form. The OSF was restored to as good as can be expected pulling out 5-6 mm dents, took about 2 hours with lots of working the area but no filler will be applied when the car goes for its blow over in white next week...... why no filler I asked also? Its a rally car not a show Queen and will most likely end up on its roof again!!! All in all a good few hours and I have been loaned a small head oscillating detailer to hopefully ‘titivate’ the MX5 paint into something more acceptable.
