Feb 10, 2021 23:13:11 GMT
As per the subject heading, I'm looking for suggestions for a material to use to make door panels. I don't want to use plywood,prefer a plastic of some kind - it will be trimmed. Also, a material to make arch liners from. I have gone to the scrappy to remove from there, but would prefer to start with new. It would only need to bend in one plane for what I'm thinking of. Thanks in advance. Neil
Might be worth looking here...https://www.woolies-trim.co.uk/category/146/millboard
Black bins for wheel arch liners?
ferny
Club RR Member Number: 13
Don't know what's it's actually like, but I've been looking at Stokbord to make undertrays for the Herald.
Feb 11, 2021 21:52:19 GMT
we used correx plastic protection sheets to make arch liners for our minor which has worked a treat, the 2mm is a bit thin we used 4mm
Feb 11, 2021 22:33:18 GMT
Stokbord sounds exactly what I have in mind. Many thanks
ferny
Feb 12, 2021 10:22:35 GMT
Stokbord sounds exactly what I have in mind. Many thanks Any feedback would be happily received if you get some. I've never worked with the stuff so not sure how well it'll hold up on cars etc.
I bought a sheet of 3mm stokbord. It will be perfect for arch liners for sure. Should be fine for my door trim backs too hopefully. Ferny, if you want a little bit to play with, pm me your address Neil
Feb 22, 2021 12:45:05 GMT
retropower ate using ABS to make door cards
ferny
I bought a sheet of 3mm stokbord. It will be perfect for arch liners for sure. Should be fine for my door trim backs too hopefully. Ferny, if you want a little bit to play with, pm me your address Neil Thanks for the offer, but I think I'm going to grab a sheet and play! Where did you manage to get it from in the end. I'm looking to get some today in 3mm flavour but I'm finding that either the price double when you add it to your basket or there's a 10 sheet minimum order.
I got it from Solway Recycling. About £16 for a sheet of 3mm, then same again for delivery. It came rolled up, but has flattened out just fine
ferny
Cheers. That's where I originally was going to go, but when I add it to the basket the price shoots up. I'll call them Monday if I get time to hide from students on the first day back!
I thought their website was odd. The unit price is about £16 but somewhere free delivery was mentioned. I'm sue the £35 something was the delivered price
