Feb 10, 2021 12:51:39 GMT
Hi all.. I'll be moving digs soon and will have a fair sized concrete garage.
I'm looking for tips and inspiration as to what people have done for shelving and storage (in past experience drilling concrete panels don't really go well)
Also how do people store there cars in this type of garage.. Would a heater or dehumidifier be a good buy or not needed
Thanks
Feb 10, 2021 16:19:28 GMT
96 Peugeot 405 Executive DTurbo Estate 89 Mazda Eunos Roadster 88 Citroen BX 16RS Previously Owned: 93 Subaru MV96 Disco 300TDI 72 LR SIII 109" Prima96 Xantia Activa 92 AX GTI 97 ZX Temptation 88 205 XS
Feb 10, 2021 17:41:49 GMT
My experience only relates to one such building that I bought back in the 70's; they sweat like nobody's business, and I never worked out how to stop it. Sold the property and moved on, leaving the problem with someone else.
Feb 10, 2021 19:11:54 GMT
On mine the walls were not too bad but the roof sweated badly, I now have the walls lined with OSB (secondhand hoarding) fixed by coachbolts through the joints and have insulated the roof and lined it with hardboard, this works fine.
Feb 10, 2021 19:40:54 GMT
Thanks for the comments by all On mine the walls were not too bad but the roof sweated badly, I now have the walls lined with OSB (secondhand hoarding) fixed by coachbolts through the joints and have insulated the roof and lined it with hardboard, this works fine. Do you have any pics of what you have done Kevin? What roof panels do you have I was considering changing it to the anti condensation lined tin sheets and maybe put a bathroom extractor fan in. Do plan on changing angle of roof at some point
mantamutilator79
I love the smell of kerosene in the morning….
Feb 10, 2021 19:49:38 GMT
I have 2 sectional concrete garages, side by side, 24’ x 11’ and 24’ x 8’. The concrete roofing sheets were a nightmare in the Winter, forming ice on the inside and dripping down when thawing, onto the cars. After 2 years, replaced with thick OSBs and roofing felt. No problems since. Storage is with a combination of roll cabinets and metal shelving. Oh, also a plastic storage cupboard.
mantamutilator79
Feb 10, 2021 19:51:48 GMT
I’ve also started lining the smaller garage with more OSBs, and have put up some old kitchen cabinets.
Feb 10, 2021 20:51:40 GMT
I have 2 sectional concrete garages, side by side, 24’ x 11’ and 24’ x 8’. The concrete roofing sheets were a nightmare in the Winter, forming ice on the inside and dripping down when thawing, onto the cars. After 2 years, replaced with thick OSBs and roofing felt. No problems since. Storage is with a combination of roll cabinets and metal shelving. Oh, also a plastic storage cupboard. Thanks four your response.. Have you any pics of this? How much did it roughly cost think mine is nearly the same size as your bigger one.. What thickness boards did you use
Years ago the council wouldn't give me planning to build myself a small garage in my back garden, so I bought a big double concrete sectional garage for just £1. Then my Dad, Uncle, Brothers, friends, workmates and I dismantled it one Saturday, and drove it all (except for the roof that was asbestos) across town to my place. The following weekend we erected it in my back garden, and roofed it with some used corrugated steel and it looked like it had been there for years. Better still, even though there was nothing there before nobody even noticed my new garage, and twenty odd years later it's still there. As has been mentioned the roof did sweat a fair bit, so I had it spray foamed which not only stopped it dripping on everything, but made it warmer, and more waterproof. Being mostly concrete though, and on a concrete slab it does tend to feel a bit damp inside during the winter months. I put in a log burning stove which did take the edge off it a bit, but in all honesty I think the best way forward would've been to insulate and line the walls too, but I never got around to that.
I have one with a sweaty asbestos roof. I've found that gap filler is pretty effective at sticking boards to the walls. I have had my electrics glued to the walls for a few years now including double sockets all around and a mini consumer unit with an armoured cable running into it and nothing's fallen off so far.
Feb 11, 2021 11:02:01 GMT
Mine has the full height vertical sections with 3 ribs, i found that it was fine to drill into the central rib with the depth stop set, its the outer two that have problems with the reinforcing wire causing massive chunks to fly off.
For condenstation I used bubble foil and spray adhesive under wriggly tin type sheets with some success. It reduced the majority of the condensation. I also increased the overhang of the roof sheets and added a dual pitch to the roof which solved issues with mositure seeping onto the floor under the walls.
bstardchild
Club RR Member Number: 71
Concrete sectional garagesbstardchild
@bstardchild
Club Retro Rides Member 71
Feb 11, 2021 11:55:06 GMT
Years ago the council wouldn't give me planning to build myself a small garage in my back garden, so I bought a big double concrete sectional garage for just £1. Then my Dad, Uncle, Brothers, friends, workmates and I dismantled it one Saturday, and drove it all (except for the roof that was asbestos) across town to my place. The following weekend we erected it in my back garden, and roofed it with some used corrugated steel and it looked like it had been there for years. Better still, even though there was nothing there before nobody even noticed my new garage, and twenty odd years later it's still there. As has been mentioned the roof did sweat a fair bit, so I had it spray foamed which not only stopped it dripping on everything, but made it warmer, and more waterproof. Being mostly concrete though, and on a concrete slab it does tend to feel a bit damp inside during the winter months. I put in a log burning stove which did take the edge off it a bit, but in all honesty I think the best way forward would've been to insulate and line the walls too, but I never got around to that. Now it's been there 20 years can you apply to replace it with a proper brick built structure?
Feb 11, 2021 13:16:57 GMT
Years ago the council wouldn't give me planning to build myself a small garage in my back garden, so I bought a big double concrete sectional garage for just £1. Then my Dad, Uncle, Brothers, friends, workmates and I dismantled it one Saturday, and drove it all (except for the roof that was asbestos) across town to my place. The following weekend we erected it in my back garden, and roofed it with some used corrugated steel and it looked like it had been there for years. Better still, even though there was nothing there before nobody even noticed my new garage, and twenty odd years later it's still there. As has been mentioned the roof did sweat a fair bit, so I had it spray foamed which not only stopped it dripping on everything, but made it warmer, and more waterproof. Being mostly concrete though, and on a concrete slab it does tend to feel a bit damp inside during the winter months. I put in a log burning stove which did take the edge off it a bit, but in all honesty I think the best way forward would've been to insulate and line the walls too, but I never got around to that. Now it's been there 20 years can you apply to replace it with a proper brick built structure? The first thing is that having been there for that length of time, you would be granted retrospective planning approval, with absolutely no problem at all. Then as suggested apply to knock it down and rebuild in brick if you so desire.
mantamutilator79
Feb 11, 2021 13:22:04 GMT
mantamutilator79
Feb 11, 2021 13:25:21 GMT
Mar 23, 2021 19:46:28 GMT
